Hi, i got problem to combine the example mqtt coding with my data sensor coding(raw python) . how to combine the two coding ?
#!/usr/bin/env python
import time
import os
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
DEBUG = 1
read SPI data from MCP3008 chip, 8 possible adc’s (0 thru 7)
def readadc(adcnum, clockpin, mosipin, misopin, cspin):
if ((adcnum > 7) or (adcnum < 0)):
return -1
GPIO.output(cspin, True)
GPIO.output(clockpin, False) # start clock low
GPIO.output(cspin, False) # bring CS low
commandout = adcnum
commandout |= 0x18 # start bit + single-ended bit
commandout <<= 3 # we only need to send 5 bits here
for i in range(5):
if (commandout & 0x80):
GPIO.output(mosipin, True)
else:
GPIO.output(mosipin, False)
commandout <<= 1
GPIO.output(clockpin, True)
adcout = 0
# read in one empty bit, one null bit and 10 ADC bits
for i in range(12):
adcout <<= 1
if (GPIO.input(misopin)):
adcout |= 0x1
adcout >>= 1 # first bit is 'null' so drop it
return adcout
change these as desired - they’re the pins connected from the
SPI port on the ADC to the Cobbler
SPICLK = 18
SPIMISO = 23
SPIMOSI = 24
SPICS = 25
set up the SPI interface pins
GPIO.setup(SPIMOSI, GPIO.OUT)
GPIO.setup(SPIMISO, GPIO.IN)
GPIO.setup(SPICLK, GPIO.OUT)
GPIO.setup(SPICS, GPIO.OUT)
10k trim pot connected to adc #0
potentiometer_adc = 0;
last_read = 0 # this keeps track of the last potentiometer value
tolerance = 5 # to keep from being jittery we’ll only change
# volume when the pot has moved more than 5 ‘counts’
while True:
# we’ll assume that the pot didn’t move
trim_pot_changed = False
# read the analog pin
trim_pot = readadc(potentiometer_adc, SPICLK, SPIMOSI, SPIMISO, SPICS)
# how much has it changed since the last read?
pot_adjust = abs(trim_pot - last_read)
if DEBUG:
print ("trim_pot:", trim_pot)
print ("pot_adjust:", pot_adjust)
print ("last_read", last_read)
if ( pot_adjust > tolerance ):
trim_pot_changed = True
if DEBUG:
print ("trim_pot_changed", trim_pot_changed)
if ( trim_pot_changed ):
set_volume = trim_pot / 10.24 # convert 10bit adc0 (0-1024) trim pot read into 0-100 volume level
set_volume = round(set_volume) # round out decimal value
set_volume = int(set_volume) # cast volume as integer
print ('Volume = {volume}%' .format(volume = set_volume))
set_vol_cmd = 'sudo amixer cset numid=1 -- {volume}% > /dev/null' .format(volume = set_volume)
os.system(set_vol_cmd) # set volume
if DEBUG:
print ("set_volume", set_volume)
print ("tri_pot_changed", set_volume)
# save the potentiometer reading for the next loop
last_read = trim_pot
# hang out and do nothing for a half second
time.sleep(0.5)
and the example mqtt
import cayenne.client
import time
Cayenne authentication info. This should be obtained from the Cayenne Dashboard.
MQTT_USERNAME = “a07bde20-634f-11ea-84bb-8f71124cfdfb”
MQTT_PASSWORD = “60271e4e4c25fb838c8d33d808293fafda7a2a43”
MQTT_CLIENT_ID = “8b609240-6473-11ea-b301-fd142d6c1e6c”
The callback for when a message is received from Cayenne.
def on_message(message):
If there is an error processing the message return an error string, otherwise return nothing.
For a secure connection use port 8883 when calling client.begin:
client.begin(MQTT_USERNAME, MQTT_PASSWORD, MQTT_CLIENT_ID, port=8883)
i=0
timestamp = 0
while True:
client.loop()
client.celsiusWrite(1, i)
client.luxWrite(2, i*10)
client.hectoPascalWrite(3, i+800)
timestamp = time.time()
i = i+1
