Hi im trying to connect Cayenne with a fila on a Raspberry, the sensors are with USB, i dont know how to call the item i need, its python.
for example:
sys:desktop:modbus.py/value.registers[1] that would be 1 of the sensors, but the code location its wrong
still got some trouble
MQTT_USERNAME = b91e27f0-276a-11eb-a2e4-b32ea624e442
invalid_syntax
you are missing ""
MQTT_USERNAME = "b91e27f0-276a-11eb-a2e4-b32ea624e442"
now i got unexpected keyword argument ´loglevel´
which python version are you using?
you can remove the import logging and , loglevel=logging.INFO
ok im having response now, but now cayenne its sending the data or my Python file is sending to cayenne?
how can i send from the Raspberry file, any data like
client.Sec[1]
or what did cliente.celsius Write(1, i) means, sure its a temperature but how can i write my values?
i am not understanding what trying to convey.
client.virtualWrite(channel, value, dataType, dataUnit)
is used to send data from the device to cayenne.
ok thanks.
Now i need to add different sensors but if i add inside the While True
if cont == 6:
client.celsiusWrite(1, sec1)
client.celsiusWrite(2, sec2)
both of the value (sec1 and sec 2) comes together, and the chart will be only 1, i need 1 for each other.
Also i need to refresh the medition, cuz looks like it repeats the first value but doesnt change in the widget
sorry, but i am not understanding what you are trying to convey.
i need one grafic for each value that im testing, insted, i have 1 grafic for 4 values.
Im testing 14 temperatures
can you share the entire code.
timestamp = 0
while True:
print(..............
client.loop()
client.celsiousWrite(i, value.register[conotador]/10)
timestamp = time.time()
if contador == 13:
...... rest of the code......
this didnt work, ant idea, i need the values to refresh every 2seg for example, it repeats the value everytime.
Also, still need to make a chart for each other insted of 1 for the 5 values
your code does not match this.
