Gas sensor trigger not working
I have a gas sensor and the notification triger not working
my code is
//#define CAYENNE_DEBUG
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
#define SENSOR_PIN 0
#define VIRTUAL_CHANNEL 1
CAYENNE_OUT(VIRTUAL_CHANNEL)
  Cayenne.virtualWrite(VIRTUAL_CHANNEL, analogRead(SENSOR_PIN), "o3", "ppm");
is your trigger counter incrementing on your trigger page.
Sorry i cannot understand, what you mean by trigger counter incrementing?
check if this value is incrementing.
ΟΚ, no it is 0
can you private message me your cayenne email.
change this
to:
Cayenne.virtualWrite(VIRTUAL_CHANNEL, analogRead(SENSOR_PIN), "analog_sensor", "null");
Remove the existing widget and when you run the code it will create a new widget.
Delete the existing trigger and add a new trigger for the new widget.
thank you. You are perfect!!
