#define pulsePin A0
#define CAYENNE_PRINT Serial
#include <CayenneMQTTESP8266.h>
// WiFi network info.
char ssid[] = "ssid";
char wifiPassword[] = "wifiPassword";
// Cayenne authentication info. This should be obtained from the Cayenne Dashboard.
char username[] = "MQTT_USERNAME";
char password[] = "MQTT_PASSWORD";
char clientID[] = "CLIENT_ID";
const int postingInterval = 10 * 1000;
int rate[10];
unsigned long sampleCounter = 0;
unsigned long lastBeatTime = 0;
unsigned long lastTime = 0, N;
int BPM = 0;
int IBI = 0;
int P = 512;
int T = 512;
int thresh = 512;
int amp = 100;
int Signal;
boolean Pulse = false;
boolean firstBeat = true;
boolean secondBeat = true;
boolean QS = false;
Cayenne.begin(username, password, clientID, ssid, wifiPassword);
if (QS == true) {
Serial.println("BPM: " + String(BPM));
QS = false;
} else if (millis() >= (lastTime + 2)) {
readPulse();
lastTime = millis();
void readPulse() {
Signal = analogRead(pulsePin);
sampleCounter += 2;
int N = sampleCounter - lastBeatTime;
detectSetHighLow();
if (N > 250) {
if ( (Signal > thresh) && (Pulse == false) && (N > (IBI / 5) * 3) )
pulseDetected();
if (Signal < thresh && Pulse == true) {
Pulse = false;
amp = P - T;
thresh = amp / 2 + T;
P = thresh;
T = thresh;
if (N > 2500) {
thresh = 512;
P = 512;
T = 512;
lastBeatTime = sampleCounter;
firstBeat = true;
secondBeat = true;
void detectSetHighLow() {
if (Signal < thresh && N > (IBI / 5) * 3) {
if (Signal < T) {
T = Signal;
if (Signal > thresh && Signal > P) {
P = Signal;
void pulseDetected() {
Pulse = true;
IBI = sampleCounter - lastBeatTime;
if (firstBeat) {
firstBeat = false;
return;
if (secondBeat) {
secondBeat = false;
for (int i = 0; i <= 9; i++) {
rate[i] = IBI;
word runningTotal = 0;
for (int i = 0; i <= 8; i++) {
rate[i] = rate[i + 1];
runningTotal += rate[i];
rate[9] = IBI;
runningTotal += rate[9];
runningTotal /= 10;
BPM = 60000 / runningTotal;
QS = true;
CAYENNE_OUT_DEFAULT()
Cayenne.virtualWrite(0, BPM);
