Cayenne widget doesn't work
I´m a Beginner with the new mqtt api. I’m using a weemos D1 mini
When i press a widget in the dashboard stucks in changing.
#define CAYENNE_DEBUG
char ssid = “";
char wifiPassword[] = "
char username = “";
char password[] = "
char clientID = “**”;
#define led_pin 4
#define virtual_led 3
int led;
pinMode(led_pin, OUTPUT);
Cayenne.virtualWrite(0, 10);
digitalWrite(led_pin, HIGH);
Cayenne.virtualWrite(3, HIGH);
CAYENNE_IN(virtual_led)
led = getValue.asInt();
CAYENNE_LOG(“Channel %d, pin %d, value %d”, virtual_led, led_pin, led);
digitalWrite(led_pin, led);
make sure that your device is online.
Yes…
can you PM me your email_id.
try this code and give it a try.
#include &lt;CayenneMQTTESP8266.h&gt;
char ssid = “ <em>";
char wifiPassword[] = "</em> ”;
char username = “ <strong>";
char password[] = "</strong> ”;
#define led_pin 4
int led;
CAYENNE_OUT_DEFAULT()
Same thing, the channel 0 increases value correctly.
try this code:
This example shows how to connect to Cayenne using an ESP8266 and send/receive sample data.
Steps:
1. If you have not already installed the ESP8266 Board Package install it using the instructions here: https://github.com/esp8266/Arduino#installing-with-boards-manager.
2. Select your ESP8266 board from the Tools menu.
char ssid[] = "ssid";
	//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
Running the code, chanel 0 receiving data.
we are looking into the issue.
@asesmero can you give it a try now by adding a new device?
Now works!, Thanks!!
