do you get an error with python3?
I don’t try this. I will inform You when I will be back home. Now I’m in work.
that is with python3. Also works:
pi@raspberrypi:~ $ cd bme680/
pi@raspberrypi:~/bme680 $ cd examples/
pi@raspberrypi:~/bme680/examples $ ls
compensated-temperature.py indoor-air-quality.py read-all.py read-cayenne.py setup.cfg temperature-offset.py temperature-pressure-humidity.py
pi@raspberrypi:~/bme680/examples $ python3 read-all.py
read-all.py - Displays temperature, pressure, humidity, and gas.
Press Ctrl+C to exit!
Calibration data:
par_gh1: -51
par_gh2: -12741
par_gh3: 18
par_h1: 880
par_h2: 990
par_h3: 0
par_h4: 45
par_h5: 20
par_h6: 120
par_h7: -100
par_p1: 37570
par_p10: 30
par_p2: -10627
par_p3: 88
par_p4: 6075
par_p5: -104
par_p6: 30
par_p7: 68
par_p8: -5847
par_p9: -1284
par_t1: 26188
par_t2: 26263
par_t3: 3
range_sw_err: 0
res_heat_range: 1
res_heat_val: 42
t_fine: 115799
Initial reading:
gas_index: 0
gas_resistance: 5696068.567757571
heat_stable: False
humidity: 36.098
meas_index: 0
pressure: 1008.06
status: 32
temperature: 22.62
Polling:
22.62 C,1008.08 hPa,36.12 %RH
22.63 C,1008.06 hPa,36.11 %RH,6662.286161804072 Ohms
22.66 C,1008.11 hPa,36.09 %RH,7925.595957416227 Ohms
22.68 C,1008.09 hPa,36.05 %RH,9582.835957350066 Ohms
22.71 C,1008.08 hPa,36.00 %RH,11340.547520715018 Ohms
22.73 C,1008.09 hPa,35.96 %RH,13193.631648248273 Ohms
22.75 C,1008.12 hPa,35.92 %RH,15128.751434122238 Ohms
22.77 C,1008.12 hPa,35.87 %RH,17009.029684977024 Ohms
try this code:
Untitled.txt (2.1 KB)
Show this and stop, don’t print live data:
pi@raspberrypi:~/Cayenne-MQTT-Python/examples $ python new_bme680.py
Calibration data:
par_gh1: -51
par_gh2: -12741
par_gh3: 18
par_h1: 880
par_h2: 990
par_h3: 0
par_h4: 45
par_h5: 20
par_h6: 120
par_h7: -100
par_p1: 37570
par_p10: 30
par_p2: -10627
par_p3: 88
par_p4: 6075
par_p5: -104
par_p6: 30
par_p7: 68
par_p8: -5847
par_p9: -1284
par_t1: 26188
par_t2: 26263
par_t3: 3
range_sw_err: 0
res_heat_range: 1
res_heat_val: 42
t_fine: 116286
Initial reading:
gas_index: 0
gas_resistance: 1977860
heat_stable: False
humidity: 37.386
meas_index: 0
pressure: 1007.8
status: 32
temperature: 22.71
after ctrl+c
^CTraceback (most recent call last):
File "new_bme680.py", line 66, in <module>
client.loop()
File "build/bdist.linux-armv6l/egg/cayenne/client.py", line 122, in loop
File "/usr/local/lib/python2.7/dist-packages/paho_mqtt-1.5.0-py2.7.egg/paho/mqtt/client.py", line 1163, in loop
socklist = select.select(rlist, wlist, [], timeout)
KeyboardInterrupt
can you just do one thing for me, i dont know what is the issue here. it should work. Can you open Example-01-SendData.py and copy code from read-all.py into it. so that it look like the new code i send you.
Do I have to erase data from Example-01-SendData.py?
no, Just edit what ever is required.
@adam do you know what is the issue here?
I would suggest putting everything in the home directory and running from there. You can get permission and or conflicting file names/libraries from running within an example directory.
cd ~
mkdir bme680_test
cd bme680_test
cp ~/Cayenne-MQTT-Python/examples/new_bme680.py new_bme680.py
Or copy w/e file you are currently working with. I see you are trying a bunch of them.
I copy code from read-all.py to Example-01-SendData.py and it works:
pi@raspberrypi:~/Cayenne-MQTT-Python/examples $ python SendData.py
Calibration data:
par_gh1: -51
par_gh2: -12741
par_gh3: 18
par_h1: 880
par_h2: 990
par_h3: 0
par_h4: 45
par_h5: 20
par_h6: 120
par_h7: -100
par_p1: 37570
par_p10: 30
par_p2: -10627
par_p3: 88
par_p4: 6075
par_p5: -104
par_p6: 30
par_p7: 68
par_p8: -5847
par_p9: -1284
par_t1: 26188
par_t2: 26263
par_t3: 3
range_sw_err: 0
res_heat_range: 1
res_heat_val: 42
t_fine: 116517
Initial reading:
gas_index: 0
gas_resistance: 3014623
heat_stable: False
humidity: 37.628
meas_index: 0
pressure: 1007.65
status: 32
temperature: 22.76
Polling:
22.76 C,1007.64 hPa,37.62 %RH
22.77 C,1007.64 hPa,37.62 %RH,12613 Ohms
22.80 C,1007.62 hPa,37.60 %RH,15227 Ohms
22.82 C,1007.60 hPa,37.55 %RH,17988 Ohms
22.85 C,1007.61 hPa,37.53 %RH,20854 Ohms
22.88 C,1007.60 hPa,37.47 %RH,23695 Ohms
22.89 C,1007.62 hPa,37.42 %RH,26614 Ohms
22.91 C,1007.63 hPa,37.37 %RH,29561 Ohms
22.93 C,1007.63 hPa,37.34 %RH,32368 Ohms
22.94 C,1007.61 hPa,37.29 %RH,35048 Ohms
22.96 C,1007.62 hPa,37.25 %RH,37526 Ohms
22.97 C,1007.63 hPa,37.22 %RH,40150 Ohms
22.98 C,1007.62 hPa,37.18 %RH,42642 Ohms
22.99 C,1007.64 hPa,37.15 %RH,45169 Ohms
23.00 C,1007.63 hPa,37.13 %RH,47149 Ohms
23.01 C,1007.64 hPa,37.11 %RH,49519 Ohms
23.01 C,1007.63 hPa,37.07 %RH,51625 Ohms
23.02 C,1007.67 hPa,37.05 %RH,53883 Ohms
23.03 C,1007.66 hPa,37.02 %RH,56122 Ohms
23.03 C,1007.65 hPa,36.99 %RH,58148 Ohms
23.04 C,1007.67 hPa,36.98 %RH,60196 Ohms
23.05 C,1007.65 hPa,36.95 %RH,62162 Ohms
23.05 C,1007.64 hPa,36.92 %RH,64064 Ohms
23.06 C,1007.63 hPa,36.90 %RH,66296 Ohms
23.06 C,1007.65 hPa,36.89 %RH,68240 Ohms
23.07 C,1007.64 hPa,36.89 %RH,69892 Ohms
23.07 C,1007.63 hPa,36.86 %RH,72305 Ohms
23.08 C,1007.65 hPa,36.84 %RH,73901 Ohms
23.09 C,1007.64 hPa,36.83 %RH,76048 Ohms
23.09 C,1007.64 hPa,36.81 %RH,77311 Ohms
23.09 C,1007.63 hPa,36.81 %RH,78989 Ohms
23.10 C,1007.65 hPa,36.79 %RH,81447 Ohms
23.10 C,1007.65 hPa,36.77 %RH,82816 Ohms
23.11 C,1007.63 hPa,36.77 %RH,84402 Ohms
23.11 C,1007.63 hPa,36.75 %RH,86049 Ohms
23.12 C,1007.65 hPa,36.75 %RH,87763 Ohms
23.12 C,1007.65 hPa,36.74 %RH,89641 Ohms
23.13 C,1007.64 hPa,36.72 %RH,91005 Ohms
23.13 C,1007.63 hPa,36.72 %RH,92615 Ohms
23.13 C,1007.62 hPa,36.69 %RH,94390 Ohms
23.14 C,1007.64 hPa,36.69 %RH,95466 Ohms
23.14 C,1007.65 hPa,36.69 %RH,95824 Ohms
23.15 C,1007.63 hPa,36.67 %RH,97554 Ohms
23.15 C,1007.62 hPa,36.67 %RH,98471 Ohms
23.16 C,1007.67 hPa,36.65 %RH,99940 Ohms
23.16 C,1007.66 hPa,36.63 %RH,101948 Ohms
23.16 C,1007.66 hPa,36.63 %RH,103523 Ohms
23.17 C,1007.65 hPa,36.62 %RH,104296 Ohms
23.17 C,1007.65 hPa,36.60 %RH,105946 Ohms
23.17 C,1007.65 hPa,36.60 %RH,107579 Ohms
23.18 C,1007.67 hPa,36.59 %RH,108979 Ohms
23.18 C,1007.66 hPa,36.59 %RH,110197 Ohms
23.18 C,1007.65 hPa,36.56 %RH,112040 Ohms
23.19 C,1007.65 hPa,36.58 %RH,112567 Ohms
23.19 C,1007.65 hPa,36.56 %RH,114805 Ohms
23.19 C,1007.67 hPa,36.53 %RH,116158 Ohms
23.20 C,1007.66 hPa,36.55 %RH,116888 Ohms
23.20 C,1007.65 hPa,36.52 %RH,118207 Ohms
23.20 C,1007.64 hPa,36.53 %RH,119986 Ohms
^CConnecting to mqtt.mydevices.com:8883
Connected with result code 0
SUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/cmd/+
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/sys/model Python
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/sys/version 1.1.0
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/1 temp,c=1
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/2 lum,lux=10
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/3 bp,hpa=801
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/1 temp,c=2
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/2 lum,lux=20
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/3 bp,hpa=802
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/1 temp,c=3
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/2 lum,lux=30
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/3 bp,hpa=803
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/1 temp,c=4
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/2 lum,lux=40
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/3 bp,hpa=804
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/1 temp,c=5
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/2 lum,lux=50
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/3 bp,hpa=805
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/1 temp,c=6
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/2 lum,lux=60
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/3 bp,hpa=806
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/1 temp,c=7
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/2 lum,lux=70
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/3 bp,hpa=807
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/1 temp,c=8
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/2 lum,lux=80
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/3 bp,hpa=808
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/1 temp,c=9
PUB v1/06487d60-1537-11ea-84bb-8f71124cfdfb/things/f9f06b50-1602-11ea-8221-599f77add412/data/2 lum,lux=90
and It show data in example dashboard:
but there’s something wrong with data. It start to send when I click
ctrl+c
excellent work. Click on the green + on the widget to make it permanent.
it is to kill the process.
That is my new code, it works but I think it need some chlittle changes:
pi@raspberrypi:~/Cayenne-MQTT-Python/examples $ cat SendData.py
#!/usr/bin/env python
import cayenne.client
import time
import bme680
import logging
print("""read-all.py - Displays temperature, pressure, humidity, and gas.
try:
sensor = bme680.BME680(bme680.I2C_ADDR_PRIMARY)
except IOError:
sensor = bme680.BME680(bme680.I2C_ADDR_SECONDARY)
# These calibration data can safely be commented
# out, if desired.
print('Calibration data:')
for name in dir(sensor.calibration_data):
if not name.startswith('_'):
value = getattr(sensor.calibration_data, name)
if isinstance(value, int):
print('{}: {}'.format(name, value))
# These oversampling settings can be tweaked to
# change the balance between accuracy and noise in
# the data.
sensor.set_humidity_oversample(bme680.OS_2X)
sensor.set_pressure_oversample(bme680.OS_4X)
sensor.set_temperature_oversample(bme680.OS_8X)
sensor.set_filter(bme680.FILTER_SIZE_3)
sensor.set_gas_status(bme680.ENABLE_GAS_MEAS)
print('\n\nInitial reading:')
for name in dir(sensor.data):
value = getattr(sensor.data, name)
sensor.set_gas_heater_temperature(320)
sensor.set_gas_heater_duration(150)
sensor.select_gas_heater_profile(0)
# Up to 10 heater profiles can be configured, each
# with their own temperature and duration.
# sensor.set_gas_heater_profile(200, 150, nb_profile=1)
# sensor.select_gas_heater_profile(1)
print('\n\nPolling:')
try:
while True:
if sensor.get_sensor_data():
output = '{0:.2f} C,{1:.2f} hPa,{2:.2f} %RH'.format(
sensor.data.temperature,
sensor.data.pressure,
sensor.data.humidity)
if sensor.data.heat_stable:
print('{0},{1} Ohms'.format(
output,
sensor.data.gas_resistance))
else:
print(output)
time.sleep(1)
except KeyboardInterrupt:
pass
MQTT_USERNAME = "06487d60-1537-11ea-84bb-8f71124cfdfb"
MQTT_PASSWORD = "23309cdee31964b2ae4caed9417b689c9bebece2"
MQTT_CLIENT_ID = "f9f06b50-1602-11ea-8221-599f77add412"
client.begin(MQTT_USERNAME, MQTT_PASSWORD, MQTT_CLIENT_ID, loglevel=logging.INFO, port=8883)
i=0
timestamp = 0
while True:
client.loop()
client.celsiusWrite(1, i)
client.luxWrite(2, i*10)
client.hectoPascalWrite(3, i+800)
timestamp = time.time()
i = i+1
ohh no, ![]()
Your code don’t work:
pi@raspberrypi:~/bme680_test $ python bme680.py
File "bme680.py", line 4, in <module>
import bme680
File "/home/pi/bme680_test/bme680.py", line 14, in <module>
AttributeError: 'module' object has no attribute 'BME680'
YEEEES ![]()
now it works. I rename it and remove bme680.py file:
@adam any thoughts on this issue?
But it shows data on example device `Device 24c6’ - that is device what was generated when I try Example_01_senddata.py and not on my device BME680.
Now I rename device and everything is OK. Thank You very much for help and Your time. Can You tell me is it posiible to also add my pm2.5 sensor [SDS011] to my dashboard in Cayenne? ![]()
I make it work with that tutorial and it autostart when reboot. Can I do it with my code to autostart:
$ crontab -e
@reboot cd /home/pi/bme680_test && ./python Example_bme680.py
yes, just add the pm2.5 code to your existing code and send it with client.virtualWrite(6, x) where x is the pm2.5 data
