Can I do it with my code to autostart:
$ crontab -e
@reboot cd /home/pi/bme680_test && ./python Example_bme680.py?
no, use @reboot python /home/pi/bme680_test/Example_bme680.py & as your crontab entry
Thanks. Can You help me where to paste that pm2.5 [sds011] code in my code from bme680?
aqi.py
#!/usr/bin/python -u
# coding=utf-8
# "DATASHEET": http://cl.ly/ekot
# https://gist.github.com/kadamski/92653913a53baf9dd1a8
from __future__ import print_function
import serial, struct, sys, time, json, subprocess
DEBUG = 0
CMD_MODE = 2
CMD_QUERY_DATA = 4
CMD_DEVICE_ID = 5
CMD_SLEEP = 6
CMD_FIRMWARE = 7
CMD_WORKING_PERIOD = 8
MODE_ACTIVE = 0
MODE_QUERY = 1
PERIOD_CONTINUOUS = 0
JSON_FILE = '/var/www/html/aqi.json'
MQTT_HOST = ''
MQTT_TOPIC = '/weather/particulatematter'
ser = serial.Serial()
ser.port = "/dev/ttyUSB0"
ser.baudrate = 9600
ser.open()
ser.flushInput()
byte, data = 0, ""
def dump(d, prefix=''):
print(prefix + ' '.join(x.encode('hex') for x in d))
def construct_command(cmd, data=[]):
assert len(data) <= 12
data += [0,]*(12-len(data))
checksum = (sum(data)+cmd-2)%256
ret = "\xaa\xb4" + chr(cmd)
ret += ''.join(chr(x) for x in data)
ret += "\xff\xff" + chr(checksum) + "\xab"
if DEBUG:
dump(ret, '> ')
return ret
def process_data(d):
r = struct.unpack('<HHxxBB', d[2:])
pm25 = r[0]/10.0
pm10 = r[1]/10.0
checksum = sum(ord(v) for v in d[2:8])%256
return [pm25, pm10]
#print("PM 2.5: {} μg/m^3 PM 10: {} μg/m^3 CRC={}".format(pm25, pm10, "OK" if (checksum==r[2] and r[3]==0xab) else "NOK"))
def process_version(d):
r = struct.unpack('<BBBHBB', d[3:])
print("Y: {}, M: {}, D: {}, ID: {}, CRC={}".format(r[0], r[1], r[2], hex(r[3]), "OK" if (checksum==r[4] and r[5]==0xab) else "NOK"))
def read_response():
byte = 0
while byte != "\xaa":
byte = ser.read(size=1)
d = ser.read(size=9)
if DEBUG:
dump(d, '< ')
return byte + d
def cmd_set_mode(mode=MODE_QUERY):
ser.write(construct_command(CMD_MODE, [0x1, mode]))
read_response()
def cmd_query_data():
ser.write(construct_command(CMD_QUERY_DATA))
d = read_response()
values = []
if d[1] == "\xc0":
values = process_data(d)
return values
def cmd_set_sleep(sleep):
mode = 0 if sleep else 1
ser.write(construct_command(CMD_SLEEP, [0x1, mode]))
read_response()
def cmd_set_working_period(period):
ser.write(construct_command(CMD_WORKING_PERIOD, [0x1, period]))
read_response()
def cmd_firmware_ver():
ser.write(construct_command(CMD_FIRMWARE))
d = read_response()
process_version(d)
def cmd_set_id(id):
id_h = (id>>8) % 256
id_l = id % 256
ser.write(construct_command(CMD_DEVICE_ID, [0]*10+[id_l, id_h]))
read_response()
def pub_mqtt(jsonrow):
cmd = ['mosquitto_pub', '-h', MQTT_HOST, '-t', MQTT_TOPIC, '-s']
print('Publishing using:', cmd)
with subprocess.Popen(cmd, shell=False, bufsize=0, stdin=subprocess.PIPE).stdin as f:
json.dump(jsonrow, f)
if __name__ == "__main__":
cmd_set_sleep(0)
cmd_firmware_ver()
cmd_set_working_period(PERIOD_CONTINUOUS)
cmd_set_mode(MODE_QUERY);
while True:
cmd_set_sleep(0)
for t in range(15):
values = cmd_query_data();
if values is not None and len(values) == 2:
print("PM2.5: ", values[0], ", PM10: ", values[1])
time.sleep(2)
# open stored data
try:
with open(JSON_FILE) as json_data:
data = json.load(json_data)
except IOError as e:
data = []
# check if length is more than 100 and delete first element
if len(data) > 100:
data.pop(0)
# append new values
jsonrow = {'pm25': values[0], 'pm10': values[1], 'time': time.strftime("%d.%m.%Y %H:%M:%S")}
data.append(jsonrow)
# save it
with open(JSON_FILE, 'w') as outfile:
json.dump(data, outfile)
if MQTT_HOST != '':
pub_mqtt(jsonrow)
print("Going to sleep for 1 min...")
cmd_set_sleep(1)
time.sleep(60)
I try Your way and my in cronetab and itās offline when I reboot ![]()
After the line import serial, struct, sys, time, json, subprocess put time.sleep(30) #Sleep to allow wireless to connect before starting MQTT Even if you donāt use wireless itās a good idea to sleep for a little to allow the Pi to get an IP address. If you donāt want to wait 30 secs you can try something lower. Even 10 seconds should be plenty if you have a pi 3 or newer.
try this simple code:
import time
def hexShow(argv):
result = ''
hLen = len(argv)
for i in range(hLen):
hvol = argv[i]
hhex = '%02x'%hvol
result += hhex+' '
print ('hexShow:',result)
t = serial.Serial('/dev/ttyAMA0',9600)
t.setTimeout(1.5)
while True:
t.flushInput()
time.sleep(0.5)
retstr = t.read(10)
hexShow(retstr)
if len(retstr)==10:
if(retstr[0]==0xaa and retstr[1]==0xc0):
checksum=0
for i in range(6):
checksum=checksum+int(retstr[2+i])
if checksum%256 == retstr[8]:
pm25=int(retstr[2])+int(retstr[3])*256
pm10=int(retstr[4])+int(retstr[5])*256
print ("pm2.5:%.1f pm10 %.1f"%(pm25/10.0,pm10/10.0))
@shramik_salgaonkar What is this code for?
@adam Sorry Iām not a programmer and I donāt know what do You mean ![]()
Replace the code at the top with this:
# coding=utf-8
DEBUG = 0
CMD_MODE = 2
CMD_QUERY_DATA = 4
CMD_DEVICE_ID = 5
Basically you just want to add the time.sleep part.
to get pm2.5 sensor data.
I donāt know of coding but Your code is too short for me
@shramik_salgaonkar
pi@raspberrypi:~ $ python pm_sensor.py
File "pm_sensor.py", line 11, in <module>
NameError: name 'serial' is not defined
@adam I donāt understand what for is that time.sleep(30) #Sleep to allow wireless to connect before starting MQTT
and how it help me to see that sensor in dashboard?
Did it work when you put it in?
I have that two files:
aqi.py - start on boot my sensor and show data in local server in browser:
# coding=utf-8
DEBUG = 0
CMD_MODE = 2
CMD_QUERY_DATA = 4
CMD_DEVICE_ID = 5
CMD_SLEEP = 6
CMD_FIRMWARE = 7
MODE_ACTIVE = 0
MODE_QUERY = 1
MQTT_HOST = ''
ser.baudrate = 9600
ser.open()
ser.flushInput()
byte, data = 0, ""
if DEBUG:
dump(ret, '> ')
return ret
pm25 = r[0]/10.0
pm10 = r[1]/10.0
return [pm25, pm10]
byte = 0
if DEBUG:
dump(d, '< ')
return byte + d
read_response()
d = read_response()
values = []
if d[1] == "\xc0":
return values
read_response()
read_response()
d = read_response()
process_version(d)
def cmd_set_id(id):
id_l = id % 256
read_response()
cmd_set_sleep(0)
cmd_firmware_ver()
while True:
cmd_set_sleep(0)
for t in range(15):
time.sleep(2)
# open stored data
try:
data = []
if len(data) > 100:
data.pop(0)
# append new values
# save it
if MQTT_HOST != '':
pub_mqtt(jsonrow)
cmd_set_sleep(1)
time.sleep(60)
and
Example_bme680.py - show bme680 sendos data in Cayenne dashboard when I do python Example_bme680.py.
#!/usr/bin/env python
import cayenne.client
import time
import bme680
import logging
print("""read-all.py - Displays temperature, pressure, humidity, and gas.
Press Ctrl+C to exit!
try:
sensor = bme680.BME680(bme680.I2C_ADDR_PRIMARY)
except IOError:
sensor = bme680.BME680(bme680.I2C_ADDR_SECONDARY)
# These calibration data can safely be commented
# out, if desired.
print('Calibration data:')
for name in dir(sensor.calibration_data):
if not name.startswith('_'):
value = getattr(sensor.calibration_data, name)
if isinstance(value, int):
print('{}: {}'.format(name, value))
# These oversampling settings can be tweaked to
# change the balance between accuracy and noise in
# the data.
sensor.set_humidity_oversample(bme680.OS_2X)
sensor.set_pressure_oversample(bme680.OS_4X)
sensor.set_temperature_oversample(bme680.OS_8X)
sensor.set_filter(bme680.FILTER_SIZE_3)
sensor.set_gas_status(bme680.ENABLE_GAS_MEAS)
MQTT_USERNAME = "06487d60-1537-11ea-84bb-8f71124cfdfb"
MQTT_PASSWORD = "23309cdee31964b2ae4caed9417b689c9bebece2"
MQTT_CLIENT_ID = "f9f06b50-1602-11ea-8221-599f77add412"
client.begin(MQTT_USERNAME, MQTT_PASSWORD, MQTT_CLIENT_ID, loglevel=logging.INFO, port=8883)
i=0
timestamp = 0
print('\n\nInitial reading:')
for name in dir(sensor.data):
value = getattr(sensor.data, name)
sensor.set_gas_heater_temperature(320)
sensor.set_gas_heater_duration(150)
sensor.select_gas_heater_profile(0)
# Up to 10 heater profiles can be configured, each
# with their own temperature and duration.
# sensor.set_gas_heater_profile(200, 150, nb_profile=1)
# sensor.select_gas_heater_profile(1)
print('\n\nPolling:')
try:
while True:
client.loop()
if sensor.get_sensor_data():
output = '{0:.2f} C,{1:.2f} hPa,{2:.2f} %RH'.format(
sensor.data.temperature,
sensor.data.pressure,
sensor.data.humidity)
if sensor.data.heat_stable:
print('{0},{1} Ohms'.format(
output,
sensor.data.gas_resistance))
else:
print(output)
client.celsiusWrite(1, sensor.data.temperature)
client.hectoPascalWrite(2, sensor.data.pressure)
client.virtualWrite(3, sensor.data.humidity,"rel_hum","p")
client.virtualWrite(4, sensor.data.gas_resistance, "co","ohms")
timestamp = time.time()
time.sleep(1)
except KeyboardInterrupt:
pass
while True:
client.loop()
client.celsiusWrite(1, i)
client.luxWrite(2, i*10)
client.hectoPascalWrite(3, i+800)
i = i+1
Please can You help me combine those two files to make my pm sensor [SDS011] be visible in Cayenne Dashboard?
do you have a link to this sensor?
@shramik_salgaonkar As I say I make everything with that TUTORIAL
@adam when I put that line to my aqi.py file my PM sensor donāt show me data on my local server
OK, I donāt want to waste Your time and I will stay with my local server for that SDS011 sensor. Just help me to add my Example_bme680.py file wright to cronetab.
Share the complete code you have that is working now and Iāll add the line to it.
import time
import bme680
import logging
import serial
import struct
import sys
import time
import json
import subprocess
DEBUG = 0
CMD_MODE = 2
CMD_QUERY_DATA = 4
CMD_DEVICE_ID = 5
CMD_SLEEP = 6
CMD_FIRMWARE = 7
MODE_ACTIVE = 0
MODE_QUERY = 1
ser.baudrate = 9600
ser.open()
ser.flushInput()
byte, data = 0, ""
data += [0, ]*(12-len(data))
checksum = (sum(data)+cmd-2) % 256
if DEBUG:
dump(ret, '> ')
return ret
pm25 = r[0]/10.0
pm10 = r[1]/10.0
checksum = sum(ord(v) for v in d[2:8]) % 256
return [pm25, pm10]
r[3]), "OK" if (checksum == r[4] and r[5] == 0xab) else "NOK"))
byte = 0
if DEBUG:
dump(d, '< ')
return byte + d
read_response()
d = read_response()
values = []
if d[1] == "\xc0":
return values
read_response()
read_response()
d = read_response()
process_version(d)
def cmd_set_id(id):
id_h = (id >> 8) % 256
id_l = id % 256
read_response()
print("""read-all.py - Displays temperature, pressure, humidity, and gas.Press Ctrl+C to exit!""")
try:
except IOError:
# out, if desired.
# the data.
i = 0
timestamp = 0
cmd_set_sleep(0)
cmd_firmware_ver()
try:
while True:
client.loop()
# cmd_set_sleep(0)
for t in range(15):
time.sleep(2)
output,
else:
print(output)
client.virtualWrite(3, sensor.data.humidity, "rel_hum", "p")
client.virtualWrite(4, sensor.data.gas_resistance, "co", "ohms")
client.virtualWrite(5, values[0], "pm", "mg")
client.virtualWrite(6, values[1], "pm", "mg")
time.sleep(1)
pass
@adam I share my codes above:
aqi.py is for SDS011 sensor and Example_bme680.py is for BME680 sensor. Both are working but bme680 donāt start on boot and stop working when I close my ssh terminal on laptop.
