I also looked at the code you helped skweresp with and I figured this would be better since it has worked for another user.
traceback on this code:
Connecting to mqtt.mydevices.com:8883
File “caytest1.py”, line 140, in
cmd_set_sleep(0)
File “caytest1.py”, line 111, in cmd_set_sleep
ser.write(construct_command(CMD_SLEEP, [0x1, mode]))
File “/usr/lib/python3/dist-packages/serial/serialposix.py”, line 532, in write
d = to_bytes(data)
File “/usr/lib/python3/dist-packages/serial/serialutil.py”, line 63, in to_bytes
raise TypeError(‘unicode strings are not supported, please encode to bytes: {!r}’.format(seq))
TypeError: unicode strings are not supported, please encode to bytes: ‘ª´\x06\x01\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00ÿÿ\x06«’
code:
#!/usr/bin/python -u
# coding=utf-8
# "DATASHEET": http://cl.ly/ekot
# https://gist.github.com/kadamski/92653913a53baf9dd1a8
from __future__ import print_function
import serial, struct, sys, time, json, subprocess
import cayenne.client
import time
import logging
MQTT_USERNAME = "efda9010-e0cc-11ea-a67f-15e30d90bbf4"
MQTT_PASSWORD = "ce0d7134567d31ef0df8b593d4f15905e8da7820"
MQTT_CLIENT_ID = "36818710-e1b5-11ea-b767-3f1a8f1211ba"
client.begin(MQTT_USERNAME, MQTT_PASSWORD, MQTT_CLIENT_ID, loglevel=logging.INFO, port=8883)
i = 0
timestamp = 0
DEBUG = 0
CMD_MODE = 2
CMD_QUERY_DATA = 4
CMD_DEVICE_ID = 5
CMD_SLEEP = 6
CMD_FIRMWARE = 7
CMD_WORKING_PERIOD = 8
MODE_ACTIVE = 0
MODE_QUERY = 1
PERIOD_CONTINUOUS = 0
JSON_FILE = '/var/www/html/aqi.json'
MQTT_HOST = ''
MQTT_TOPIC = '/weather/particulatematter'
ser = serial.Serial()
ser.port = "/dev/ttyUSB0"
ser.baudrate = 9600
ser.open()
ser.flushInput()
byte, data = 0, ""
def dump(d, prefix=''):
print(prefix + ' '.join(x.encode('hex') for x in d))
def construct_command(cmd, data=[]):
assert len(data) <= 12
data += [0, ] * (12 - len(data))
checksum = (sum(data) + cmd - 2) % 256
ret = "\xaa\xb4" + chr(cmd)
ret += ''.join(chr(x) for x in data)
ret += "\xff\xff" + chr(checksum) + "\xab"
if DEBUG:
dump(ret, '> ')
return ret
def process_data(d):
r = struct.unpack('<HHxxBB', d[2:])
pm25 = r[0] / 10.0
pm10 = r[1] / 10.0
checksum = sum(ord(v) for v in d[2:8]) % 256
return [pm25, pm10]
# print("PM 2.5: {} μg/m^3 PM 10: {} μg/m^3 CRC={}".format(pm25, pm10, "OK" if (checksum==r[2] and r[3]==0xab) else "NOK"))
def process_version(d):
r = struct.unpack('<BBBHBB', d[3:])
print("Y: {}, M: {}, D: {}, ID: {}, CRC={}".format(r[0], r[1], r[2], hex(r[3]),
"OK" if (checksum == r[4] and r[5] == 0xab) else "NOK"))
def read_response():
byte = 0
while byte != "\xaa":
byte = ser.read(size=1)
d = ser.read(size=9)
if DEBUG:
dump(d, '< ')
return byte + d
def cmd_set_mode(mode=MODE_QUERY):
ser.write(construct_command(CMD_MODE, [0x1, mode]))
read_response()
def cmd_query_data():
ser.write(construct_command(CMD_QUERY_DATA))
d = read_response()
values = []
if d[1] == "\xc0":
values = process_data(d)
return values
def cmd_set_sleep(sleep):
mode = 0 if sleep else 1
read_response()
def cmd_set_working_period(period):
ser.write(construct_command(CMD_WORKING_PERIOD, [0x1, period]))
read_response()
def cmd_firmware_ver():
ser.write(construct_command(CMD_FIRMWARE))
d = read_response()
process_version(d)
def cmd_set_id(id):
id_h = (id >> 8) % 256
id_l = id % 256
ser.write(construct_command(CMD_DEVICE_ID, [0] * 10 + [id_l, id_h]))
read_response()
def pub_mqtt(jsonrow):
cmd = ['mosquitto_pub', '-h', MQTT_HOST, '-t', MQTT_TOPIC, '-s']
print('Publishing using:', cmd)
with subprocess.Popen(cmd, shell=False, bufsize=0, stdin=subprocess.PIPE).stdin as f:
json.dump(jsonrow, f)
cmd_set_sleep(0)
cmd_firmware_ver()
cmd_set_working_period(PERIOD_CONTINUOUS)
cmd_set_mode(MODE_QUERY);
while True:
client.loop()
if (time.time() > timestamp + 62):
cmd_set_sleep(0)
for t in range(15):
values = cmd_query_data();
if values is not None and len(values) == 2:
print("PM2.5: ", values[0], ", PM10: ", values[1])
time.sleep(2)
client.virtualWrite(0, values[0])
client.virtualWrite(1, values[1])
print("Going to sleep for 1 min...")
cmd_set_sleep(1)
timestamp = time.time()
