Hello, is it possible to use a push button on a RaspberryPi gpio pin to control a relay pin at the Pi location instead of using the app all the time?
Input button
Hello, I was looking for away to make sure a 30 cup coffee pot gets turned off. Need away to turn on the power at the pot and also be able to shut it off if it gets left on from the app. I was planning on using a temp sensor ds18b20, a power switch tail, and a push button.
Thanks.
rather then raspberry pi, i would say go for an arduino device as it will be more suitable for your use case
I bought a couple of Wemos D1 Minis for $3.99. They have built in wireless using the ESP8266 chip, and get their power from a mini usb plug.
No extra adapters needed to program, board is about 2" square. Highly recommend!
Just saw that BangGood also has a package deal for $5.58 that has a V2.2.0 D1 with a relay shield here:
Wemos D1 Mini V2.2.0 w/ Relay Shield
Thingiverse also has several 3d printable cases that allow / enclose this setup:
Thiniverse: D1 Mini Cases
