Device & model you are using :Dragino LHT65
What dashboard are you using?Web
I can not add/drag all the widgets under the device to the project window, it only allows four. I have tried to drag the device into the project window then select all the widgets and also tried to drag the widget into the project window, all without success.
When I click on the device it is showing all the data, so I know it is being passed from TTN to Cayennne.
Any ideas?
