anyone know how i can add gps functionality to this?
#define TINY_GSM_DEBUG Serial
#define TINY_GSM_MODEM_SIM7000
#define USE_GSM //! Uncomment will use SIM7000 for GSM communication
#ifdef USE_GSM
#include <CayenneMQTTGSM.h>
#else
#include <CayenneMQTTESP32.h>
#endif
#include <Arduino.h>
#include <Wire.h>
#define BATTERY_VIRTUAL_CHANNEL 1
#define SOLAR_VIRTUAL_CHANNEL 2
#define PIN_TX 27
#define PIN_RX 26
#define UART_BAUD 9600
#define PWR_PIN 4
#define BAT_ADC 35
#define SOLAR_ADC 36
HardwareSerial gsmSerial(1);
#ifdef USE_GSM
// GSM connection info.
char apn[] = "vzwinternet"; // Access point name. Leave empty if it is not needed. I Know verizon is data only.
char gprsLogin[] = ""; // GPRS username. Leave empty if it is not needed.
char gprsPassword[] = ""; // GPRS password. Leave empty if it is not needed.
char pin[] = ""; // SIM pin number. Leave empty if it is not needed.
#else
char ssid[] = "";
char wifiPassword[] = "";
#endif
char username[] = "";
char password[] = "";
char clientID[] = "";
bool bmpSensorDetected = true;
Serial.begin(UART_BAUD);
gsmSerial.begin(UART_BAUD, SERIAL_8N1, PIN_RX, PIN_TX);
pinMode(PWR_PIN, OUTPUT);
//Launch SIM7000
digitalWrite(PWR_PIN, HIGH);
delay(300);
digitalWrite(PWR_PIN, LOW);
//Wait for the SIM7000 communication to be normal, and will quit when receiving any byte
int i = 6;
delay(200);
while (i) {
Serial.println("Send AT");
gsmSerial.println("AT");
if (gsmSerial.available()) {
String r = gsmSerial.readString();
Serial.println(r);
break;
delay(1000);
i--;
#ifdef USE_GSM
Cayenne.begin(username, password, clientID, gsmSerial, apn, gprsLogin, gprsPassword, pin);
#else
#endif
CAYENNE_IN_DEFAULT()
CAYENNE_IN(1)
float readBattery(uint8_t pin)
int vref = 1100;
uint16_t volt = analogRead(pin);
float battery_voltage = ((float)volt / 4095.0) * 2.0 * 3.3 * (vref);
return battery_voltage;
CAYENNE_OUT(BATTERY_VIRTUAL_CHANNEL)
float mv = readBattery(BAT_ADC);
Serial.printf("batter : %f\n", mv);
Cayenne.virtualWrite(BATTERY_VIRTUAL_CHANNEL, mv, TYPE_VOLTAGE, UNIT_MILLIVOLTS);
CAYENNE_OUT(SOLAR_VIRTUAL_CHANNEL)
float mv = readBattery(SOLAR_ADC);
Serial.printf("solar : %f\n", mv);
Cayenne.virtualWrite(SOLAR_VIRTUAL_CHANNEL, mv, TYPE_VOLTAGE, UNIT_MILLIVOLTS);
