I started working with Cayenne for an IoT project and at thebeginning you’re supposed to choose a device. I chose Arduino Uno with ESP8266 wifi module, which opened up a sketch that says to use Serial1 pins that are available in the Arduino MEGA board. It is futher written that i can use the software serial pins and it is written that they are unstable however I can’t even find those. Really need help please!
this is the code to use with arduino uno
Steps:
2. Connect the ESP8266 as a shield to your Arduino. This example uses the Serial hardware serial pins available on the UNO.
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
#define EspSerial Serial
ESP8266 wifi(&EspSerial);
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
Thank you so much!
Do i just continue with the instructions of the previous sketch or?
everything is same except you need to connect the esp to serial pins of arduino.
I have connected but I am not sure where to define them in the code. Sorry i’m just really new to this.
it is already defined in the code.
I’m unable to upload the code.
This is the error I am getting;
Arduino: 1.9.0-beta (Windows 10), Board: “Arduino/Genuino Uno”
Sketch uses 20730 bytes (64%) of program storage space. Maximum is 32256 bytes.
Global variables use 1140 bytes (55%) of dynamic memory, leaving 908 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
you have to disconnect the esp from uno while uploading the code and then connect it once done.
And then upload the code again?
no. once uploaded you can connect the esp.
its still saying waiting for board to connect
what is the serial monitor output?
on the Cayenne website to create the dashboard, it;s saying that it is waiting for the board to connect. The code has uploaded, and I have connected the ESP, but the dashboard is taking long ![]()
share the output here.
its blank
set the baud rate 115200
13:52:45.966 → AT
13:52:48.509 → AT
13:52:51.006 → AT
13:52:53.518 → AT
13:52:56.010 → AT
13:52:58.514 → AT
13:53:01.058 → AT
13:53:03.560 → AT
13:53:06.067 → AT
13:53:07.715 → AT
13:53:08.016 → AT
13:53:08.049 → AT
13:53:08.617 → AT
13:53:09.526 → AT
13:53:12.091 → AT
13:53:14.586 → AT
13:53:17.115 → AT
13:53:19.607 → AT
13:53:22.129 → AT
13:53:24.646 → AT
this is the output from my serial monitor
