MAX30100 Problem
Hi guys, I am facing a problem with Cayenne and MAX30100 using ESP8266.
I am trying to get data from max30100 to cayenne but when I do that I give me zero values. I did try to change the delay tim ing but nothing works. Before getting the data on Cayenne, I did test the sensor and it was working fine.
Does that value display correctly if you log the same one you are sending to debug?
