Momentary Button
Hi… I trying to come up with a one shot button that automatically resets back to state 0.
Will this work? I ask because it isn’t… Channel 5 never goes back to 0.
CAYENNE_OUT_DEFAULT()
Cayenne.virtualWrite(5, 0, “digital_sensor”, “d”);
CAYENNE_IN(5)
value = getValue.asInt();
if (value == 1){
digitalWrite(RELAY, 1);
delay(500);
digitalWrite(RELAY, 0);
Did you try it on the cayenne app? try this code:
  Steps:
  1. Set the Cayenne authentication info to match the authentication info from the Dashboard.
  2. Compile and upload the sketch.
  3. A temporary widget will be automatically generated in the Cayenne Dashboard. To make the widget permanent click the plus sign on the widget.
#define CAYENNE_DEBUG       // Uncomment to show debug messages
char username[] = "";
char password[] = "";
char clientID[] = "";
int x = 0;
unsigned long lastMillis = 0;
  if (x == 1) {
      Serial.println("Switch is OFF");
      Cayenne.virtualWrite(5, 0);
      x = 0;
CAYENNE_IN(5)
  int  value = getValue.asInt();
  if (value == 1) {
    Serial.println("switch is ON");
    x = 1;
    lastMillis = millis();
Hi… No I never was looking at the app… So I did and you are correct… The app will show the button turn off (State 0)… So what up on the dashboard then? You see the off command but Test button is still State 1…
there is an issue with the web dashboard, we are looking into it.
