My problem is having a momentary switch on an Arduino digital input register at Cayenne. The switch is on for a second and most of the time not when the Arduino is reading the inputs. (Update every 60 seconds, the odds are zip.) A trigger I have set up will notify me. I feel like I’m missing the obvious.
John
you can give this code.
int previousState = -1;
int currentState = -1;
void checkSensor()
if (currentMillis - previousMillis >= 250) {
currentState = digitalRead(SENSOR_PIN);
Cayenne.virtualWrite(VIRTUAL_CHANNEL, currentState);
previousState = currentState;
I’m not sure how it should be incorporated in the existing code. I tried about everything, but always an error of some sort. The code worked until I tried adding your snippet. Here’s the latest.
Thank You!
John
Full code::
#define SENSOR_PIN 14 // AC Fail
#define SENSOR_PIN 16 // Status
#define SENSOR_PIN 13 // Intrusion
#include <DHT_U.h>
#define DHTPIN 5
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
char ssid[] = "J";
char wifiPassword[] = "ZZZ";
char username[] = "ZZZZZZZ";
char password[] = "ZZZ";
char clientID[] = "ZZZZZZZZZZ";
unsigned long lastMillis = 0;
pinMode(12, OUTPUT);
dht.begin();
// sensor_t sensor;
void checkSensor()
{ unsigned long currentMillis = millis();
//Publish data every 60 seconds (60000 milliseconds).
if (millis() - lastMillis > 30000)
lastMillis = millis();
sensors_event_t event;
Cayenne.virtualWrite(5, dht.readTemperature(true),"temp","f");
Cayenne.virtualWrite(4, dht.readHumidity(),"rel_hum","p");
Cayenne.virtualWrite(14, digitalRead(14), "digital_sensor", "d"); // ac fail
Cayenne.virtualWrite(16, digitalRead(16), "digital_sensor", "d"); // status
Cayenne.virtualWrite(13, digitalRead(13), "digital_sensor", "d"); // intrusion
int battReading = analogRead(A0); // read the input on analog pin 0 // Battery
float volts = battReading * 3.3; // converting that reading to voltage, which is based off the reference voltage
volts /= 1024.0;
float volts1 = volts * 3.8; // factor to correct for external voltage divider on ADC input
Cayenne.virtualWrite(17, volts1, "voltage", "v");
long rssi = WiFi.RSSI();
Cayenne.virtualWrite(6, rssi, "rssi", "dbm");
CAYENNE_IN(12)
int value = getValue.asInt();
digitalWrite(12, value);
you are missing }
in void loop()
