Hi team cayenne.
I have a problem with my relay when I connected a water pump.
The fact is that when I use the relay with normal arduino it turns off and on correctly, but when I want to turn it off with cayenne the board disconnects and the pump does not turn off. However, if I connect an LED to the relay it works well with cayenne, it only happens when I connect the pump.
My component are:
Arduino uno
Ethernet shield w5100
Pump halija DC3- 5v
The error message when i put the pin in 0:
[0] MAC: xxx
[7519] IP: xxx
[7520] Connecting to mqtt.mydevices.com:1883
[7843] Connected
[11456] CAYENNE_IN_DEFAULT(1) - xGv0HJMJwGM7yoF, 1
[106452] Disconnected
[106454] Connecting to mqtt.mydevices.com:1883
[108284] Network connect failed
[111111] Network connect failed
[113937] Network connect failed
The code is:
char username = “xx”;
char password = “xx”;
char clientID = “xx”;
#define VIRTUAL_CHANNEL 1
#define ACTUATOR_PIN 7
CAYENNE_IN(VIRTUAL_CHANNEL)
if (getValue.asInt() == 1) {
digitalWrite(ACTUATOR_PIN, HIGH);
else {
digitalWrite(ACTUATOR_PIN, LOW);
