Hello all. I just finished one project to control my aquarium I am using an arduino Uno and an ethernet shield W5100. I control 2 relays to control my pump and filter, and I control 4 servos towerpro to control an automatic feeder. I was making trials with the code separately I mean I tested relays at the begin then 1 servo then 2 servos and everything was OK. However once I put all the code together it does not work anymore cayenne says the device is offline and my ethernet shield only turn on one red led. This is my code:
Cayenne Servo Motor Example
This sketch sample file shows how to connect a Servo Motor with CayenneMQTT Library.
Steps:
- Install the Servo library from the Arduino Library Manager.
- In the Cayenne Dashboard add a new Servo Motor widget.
- Select a virtual channel number for the widget.
- Set min value to 0 and max value to 1.
- Set the VIRTUAL_CHANNEL value below to the virtual channel you selected.
- Connect the Servo’s legs to GND, VCC (5.0), and a digital pin.
- Set the ACTUATOR_PIN value below to the digital pin number you selected.
- Compile and upload this sketch.
- Once the Arduino connects to the Dashboard you can use the slider to change the servo position.
#include <Servo.h>
#include <OneWire.h>
char username = “2df4fc80-c9d4-11e8-ac9c-271082632120”;
char password = “1276fc458e1e689d9e35efa7d15cf33c5795a5e2”;
char clientID = “50fb2450-c9e5-11e8-90bb-9f05022e95b7”;
#define VIRTUAL_CHANNEL 1
#define ACTUATOR_PIN 4
#define VIRTUAL_CHANNEL 2
#define ACTUATOR_PIN 5
#define VIRTUAL_CHANNEL 3
#define ACTUATOR_PIN 6
#define VIRTUAL_CHANNEL 4
#define ACTUATOR_PIN 7
#define VIRTUAL_CHANNEL 5
#define ACTUATOR_PIN 8
#define VIRTUAL_CHANNEL 6
#define ACTUATOR_PIN 9
#define SENSOR_PIN 10
#define VIRTUAL_CHANNEL 7
Servo s1;
Servo s2;
Servo s3;
Servo s4;
OneWire oneWire(10);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
s1.attach(6);
s2.attach(7);
s3.attach(8);
s4.attach(9);
sensors.begin();
CAYENNE_OUT(7)
Cayenne.celsiusWrite(7, sensors.getTempCByIndex(0));
CAYENNE_IN(1)
// Encender y apagar el rele numero 1 conectado a un ventilador
if (getValue.asInt() == 0) {
digitalWrite(4, HIGH);
else {
digitalWrite(4, LOW);
CAYENNE_IN(2)
// Encender y apagar rele numero 2 cobectado al calentador.
digitalWrite(5, HIGH);
else {
digitalWrite(5, LOW);
CAYENNE_IN(3)
// Varia el angulo del servo para dimmear las luces amanecer.
int position = getValue.asDouble() * 90;
// Move the servo to the specified position.
s1.write(position);
CAYENNE_IN(4)
// Varia el angulo del servo para dimmear las luces de día.
s2.write(position);
CAYENNE_IN(5)
// Varia el angulo del servo para dimmear las luces anochecer.
s3.write(position);
CAYENNE_IN(6)
// Varia el angulo del servo para accionar el alimentador autmatico.
int value = getValue.asInt();
int position4 = value * 180;
s4.write(position4);
