My project runs properly and the connection is ok from the beginning but, sometimes it disconnects and connect again by itself (after 2-4 seconds). Is it normal?. Can i avoid it ?.
Thank you.
Regards
Thank you.
Regards
what is the serial monitor output during the disconnect?
This is the serial monitor´s message during a disconnect/ re-connect cicle.
[105937] Disconnected
[105937] Connecting to mqtt.mydevices.com:1883
[106212] Connected
add #define CAYENNE_DEBUG in the code and share the serial monitor output.
I am getting a similar result in the serial monitor
[52659] Disconnected
[52659] Connecting to mqtt.mydevices.com:1883
[52956] Connected
can you share your entire code.
This is the result after 5 minutes running. I have checked and the diconnections occurs when i run the mobile phone app and press buttons.
[1560] IP: 192.168.1.41
[1561] Connecting to mqtt.mydevices.com:1883
[2439] Connected
[56914] Disconnected
[56915] Connecting to mqtt.mydevices.com:1883
[57198] Connected
[89306] Disconnected
[89307] Connecting to mqtt.mydevices.com:1883
[89570] Connected
[133065] Disconnected
[133066] Connecting to mqtt.mydevices.com:1883
[133330] Connected
seems an issue with your device.
I have bought a new arduino´s internet shield (i was working with a W5100 model and now, I´m working with a W5500 one) but the problem doesn´t disappear. It is connecting and disconnecting continuously from cayenne´s server.
I´m desesperate because i don´t have any idea about the problem and i don´t make my project because it´s a home made alarm system, that´s why it has to be running without interrupts.
do you have any idea?.
Thank you in advance.
Regards
you can try using esp device. I had kept it running for 24hrs straight and did not disconnect.
can you share the arduino code you have uploaded?
I have an ESP8266 device but i am not able to connect my arduino to internet (using this device). ¿Could you send me an example of arduino code and a connection diagram (wire diagram) in order to check my ESP device?. I look for a valid example in internet but, i don’t find anything.
Thank you.
which esp device are you referring to. can you share a link of it?
This is my device:
https://components101.com/wireless/esp8266-pinout-configuration-features-datasheet
do you have an arduino mega? the esp as shield is stable only for arduino mega as it has secondary serial pins Cayenne-MQTT-Arduino/ESP8266Shield.ino at master · myDevicesIoT/Cayenne-MQTT-Arduino · GitHub
I have both models UNO and MEGA but i was working with the ESP connected to the UNO one. I´m going to change to MEGA one.
Could send me the wire diagram for this example?.
Than you
ESP ----- MEGA
VCC ---- 3.3v
GND ----- GND
TX ----- RX1
RX ----voltage divider— TX1
you will need a voltage divider.
What is the library what i have to use?. I´m getting an error message because the code use #include <CayenneMQTTESP8266Shield.h> i have download the library cayenne mqtt arduino master but i get the error while compiling the code.
Thank you
Install the ESP8266SerialLibrary.zip library via the Arduino IDE (Sketch->Include Library->Add .ZIP Library) from the Cayenne extras/libraries folder
(e.g. My Documents\Arduino\libraries\CayenneMQTT\extras\libraries) to compile this example.
i get “ESP is not responding”, i think that ESP needs a previous SET UP process.
