Hi
I’m trying and trying, but struggle to store historical data more than 1 h
I hope you can help me @shramik_salgaonkar
What I tried was
- convert weight to string
CAYENNE_OUT(VIRTUAL_CHANNEL_10)
Cayenne.virtualWrite(VIRTUAL_CHANNEL_10, weightKgStr, “digital_sensor”, “d”); // kg not in cayenne definitions
- Use a known value temp as string sinse it is a known definition
Cayenne.virtualWrite(VIRTUAL_CHANNEL_12, tempStr, “temp”, “c”);
same as 2 but as float
Cayenne.virtualWrite(VIRTUAL_CHANNEL_12, temp, “temp”, “c”);
as analog
Cayenne.virtualWrite(VIRTUAL_CHANNEL_11, AnalogKgStr, “analog_sensor”, “d”);
My test code, also include some OLED write
//Libraries for Cayenne
#include <CayenneMQTTESP32.h>
//OLED pins LoRa TTGO
#define OLED_SDA 21
#define OLED_SCL 22
#define OLED_RST 23
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET -1
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
float weightKg;
float AnalogKg;
float temp;
char weightKgStr[10]; // create a character array to store the string for Cayenne
char AnalogKgStr[10]; // create a character array to store the string for cayenne
char tempStr[10]; // create a character array to store the string for cayenne
int pixel_x = 0;
// my devices
char* username = "xxx";
char* password = "yyy";
char* clientID = "zzz";
char SSID[] = "WiFi";
char wifipass[] = "PASS";
//Cayenne channel definitions
#define VIRTUAL_CHANNEL_10 10
#define VIRTUAL_CHANNEL_11 11
#define VIRTUAL_CHANNEL_12 12
Serial.begin(57600);
// initialize OLED screen
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
while (true);
// clear screen
display.clearDisplay();
randomSeed(analogRead(0)); // seed the random number generator with an analog input value
Cayenne.begin(username, password, clientID, SSID, wifipass);
// WiFi Cayenne control
CAYENNE_CONNECTED() {
CAYENNE_LOG("Connection established");
CAYENNE_DISCONNECTED() {
CAYENNE_LOG("Connection Lost");
float weightKg = map(random(0, 100), 0, 99, 2500, 2599) / 100.0; // generate a random number between 2500 and 2599, then map it to the range 25.00 to 25.99
float AnalogKg = map(random(0, 100), 0, 99, 2000, 2099) / 100.0; // generate a random number between 2000 and 2099, then map it to the range 25.00 to 25.99
float temp = map(random(0, 100), 0, 99, 1000, 1500) / 100.0; // generate a random number between 2000 and 2099, then map it to the range 25.00 to 25.99
// convert the float to a string with two decimal places
snprintf(weightKgStr, sizeof(weightKgStr), "%.2f", weightKg); // gjør om til string for cayenne
snprintf(AnalogKgStr, sizeof(AnalogKgStr), "%.2f", AnalogKg);
snprintf(tempStr, sizeof(tempStr), "%.2f", temp);
Serial.print("Digitalvekt: ");
Serial.print(weightKgStr); // print the random number to the serial monitor with 2 decimal places
Serial.print(" Analogvekt: ");
Serial.print(AnalogKgStr); // print the random number to the serial monitor with 2 decimal places
Serial.print(" Temp/vekt: ");
Serial.println(temp); // print the random number to the serial monitor with 2 decimal places
// Send readings
unsigned long currentTime = millis();
if (currentTime - previousTime >= 10000) { // LoRa publish timer
previousTime = currentTime;
Serial.println("###################################### Sender til Cayenne 10 sek");
//writeOLED();
display.drawPixel(127, 59, 1);
int pixel_y = (weightKg - 25) * 60; //60 pix er 1 kg. Avlest vekt 22 kg - 20 kg = 2, 2*30=60
//move one pixel to rigth
Serial.println(weightKg);
Serial.print("x=" + String(pixel_x));
Serial.println(", y=" + String(pixel_y));
display.drawPixel(pixel_x, pixel_y, 1);
//move one pixel to rigth next time
pixel_x = pixel_x + 1;
if (pixel_x == 128) {
pixel_x = 0;
// update previous point to current point
//previousY = pixel_y;
// display graph on screen
display.display();
// delay for smooth animation
delay(300);
Cayenne.virtualWrite(VIRTUAL_CHANNEL_10, weightKgStr, "digital_sensor", "d"); // kg not in cayenne definitions
CAYENNE_OUT(VIRTUAL_CHANNEL_11)
Cayenne.virtualWrite(VIRTUAL_CHANNEL_11, AnalogKgStr, "analog_sensor", "d"); // kg not in cayenne definitions
CAYENNE_OUT(VIRTUAL_CHANNEL_12)
Cayenne.virtualWrite(VIRTUAL_CHANNEL_12, tempStr, "temp", "c"); // test to make kg as temp
