Noob here -
I’m trying to build a remote temp monitor using a DHT22 and ESP8266 NodeMCU. I found some coding on a project website but I keep getting an error while trying to compile it.
Here is the code -
#include <dht.h>
#include <DHT.h>
#define DHTPIN D5 // what pin the DHT is connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
const int TEMPERATURE_INTERVAL = 30;
unsigned long last_temperature_sent = 0;
const int HUMIDITY_INTERVAL = 30;
unsigned long last_humidity_sent = 0;
String display_temp;
String display_humid;
DHT dht(DHTPIN, DHTTYPE);
char ssid[] = “”;
char wifiPassword[] = “”;
char username[] = “”;
char password[] = “”;
char clientID[] = “”;
void getSendTemperature() {
if (millis() – last_temperature_sent >= TEMPERATURE_INTERVAL * 1000UL || last_temperature_sent == 0) {
float temperature = dht.readTemperature(true);
if (isnan(temperature)) {
Serial.println(“Failed to read from DHT sensor!”);
return;
display_temp = temperature;
Serial.print(“Temperature: “);
Serial.print(temperature);
Serial.println(” °F”);
Cayenne.virtualWrite(8, temperature);
last_temperature_sent = millis();
void getSendHumid() {
if (millis() – last_humidity_sent >= HUMIDITY_INTERVAL * 1000UL || last_humidity_sent == 0) {
float humidity = dht.readHumidity();
if (isnan(humidity)) {
return;
display_humid = humidity;
Serial.print(“Humidity: “);
Serial.print(humidity);
Serial.println(” %”);
Cayenne.virtualWrite(9, humidity);
last_humidity_sent = millis();
Serial.begin(230400);
dht.begin();
getSendTemperature();
getSendHumid();
CAYENNE_IN_DEFAULT()
CAYENNE_LOG(“CAYENNE_IN_DEFAULT(%u) – %s, %s”, request.channel, getValue.getId(), getValue.asString());
char ssid[] = “Your WiFi SSID”;
char wifiPassword[] = “Your WiFi PWD”;
char username[] = “Your Cayenne MQTT Username”;
char password[] = “Your Cayenne MQTT Password”;
char clientID[] = “Your Cayenne MQTT Client ID”;
return;
return;
dht.begin();
getSendHumid();
Below here is the error message(s) that I’m receiving. I’m about to pull my hair out trying to figure this out.
Arduino: 1.8.9 (Windows 7), Board: “NodeMCU 0.9 (ESP-12 Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200”
DHT22:89:108: error: macro “CAYENNE_IN_DEFAULT” passed 1 arguments, but takes just 0
DHT22:168:108: error: macro “CAYENNE_IN_DEFAULT” passed 1 arguments, but takes just 0
exit status 1
Thank you in advance for helping a new guy out.
-Miles
