About This Project
This project uses the ESP8266 NodeMCU V3 to deliver temperature and humidity.
Connection:
DHT22 pin 1 to NodeMCU vcc 3.3 volt
pin 2 to Node MCU pin 14 (D5)
pin 3 NC (not used)
pin 4 to NodeMCU GND
First Add a new generic ESP8266 device to your Cayenne dashboard
you will get:
“Your Cayenne MQTT user name id”;
“Your Cayenne MQTT password”;
“Your Cayenne MQTT Client ID”;
Flash the script below to the NodeMCU after the following modifications!
set WiFi network info:
char ssid = “Your vifi connection”;
char wifiPassword = “Your wifi password”;
Cayenne authentication info. This should be obtained from the Cayenne Dashboard.
char username = “Your Cayenne MQTT user name id”;
char password = “Your Cayenne MQTT password”;
char clientID = “Your Cayenne MQTT Client ID”;
SCRIPT
#include <PubSubClient.h>
#include <DHT.h>
#define DHTTYPE DHT22
#define DHTPIN 14
DHT dht(DHTPIN, DHTTYPE, 11);
char ssid[] = "XXXXX";
char wifiPassword[] = "XXXXX";
// Cayenne authentication info.
char username[] = "XXXXXXXX";
char password[] = "XXXXXXXX";
char clientID[] = "XXXXXXXX";
unsigned long lastMillis = 0;
Serial.begin(115200);
dht.begin();
long lastMsg = 0;
float temp = 0.0;
float hum = 0.0;
float diff = 1.0;
CAYENNE_OUT_DEFAULT()
float newTemp = dht.readTemperature();
temp = newTemp;
Serial.print("New temperature:");
Serial.println(String(temp).c_str());
Cayenne.virtualWrite(0, String(temp).c_str()); // channel 0
float newHum = dht.readHumidity();
hum = newHum;
Serial.print("New humidity:");
Serial.println(String(hum).c_str());
Cayenne.virtualWrite(1, String(hum).c_str()); // channel 1
CAYENNE_IN_DEFAULT()
getValue.setError(), e.g getValue.setError("Error message");
NOTE!
I ordered 10 DHT22 and put it under test for 1 week. The deviations are sometimes enormous, 1.5 °C and 30% humidity. After this test, I took the 5 best DHT22 for my project.
