kindly tell me where to run this code example?
on your pi terminal, run this command:
git clone https://github.com/myDevicesIoT/Cayenne-MQTT-Python
cd Cayenne-MQTT-Python
python setup.py install
Once done navigate to example folder and open Example-03-CayenneClient.py. Add your MQTT credentials which you will get when you add a new Bring Your Own thing device on the cayenne dashboard.
while running ```
"Perhaps your account does not have write access to this directory? If the
installation directory is a system-owned directory, you may need to sign in
as the administrator or "root" account. If you do not have administrative
access to this machine, you may wish to choose a different installation
directory, preferably one that is listed in your PYTHONPATH environment
variable.
For information on other options, you may wish to consult the
documentation at:
https://setuptools.readthedocs.io/en/latest/easy_install.html
Please make the appropriate changes for your system and try again.
Use sudo python setup.py install
ys it is done know how to navigate to example folder and open Example-03-CayenneClient.py?
cd examples
sudo nano Example-03-CayenneClient.py
I have write my MQTT ID, USER NMAE and password their know what next?
Save, exit and run the file: sudo python Example-03-CayenneClient.py
please tell me how I can save and exit this in terminal
To save, hold the control key down and type x then y. It will ask you for a filename (and give you a default if you opened a file) and then save it.
Go through this and first get familiar with terminal http://cs.colby.edu/maxwell/courses/tutorials/terminal/
