ok sir. Thank you for your suggestion and time.
Did you Serial.print()
the measured values?
Sir,
I am using serial connection to connect with cayenne…so not able to use serial monitor of arduino…
Because my COM port is already busy
Problem sort out now…
I have used 2nd arduino and done coding of ultrasonic sensor with two relay module which handle two different actuators…
By the way
Thank you sir for your cooperation…because of you i am not loosing my hope…still doing …and succeed…
Can you share the problem and how you solve it?
