I have a few uses for push button support in my projects. In the old version of WebIOPi it was required to check for button pushes at a timed interval, which lead to some pretty heavy load when running the loop every 0.1 seconds. It was also required to use hardware debouce for the push buttons, and software debounce would be preferred. As a reference, the interrupt style check with software debounce that node-red implemented is perfect for my uses.
Thank you for your Suggestion we will take this into consideration and pass it to the Team
We should integrate that with the GPIO driver rework that is planned after release.
any progress on this, this is deeply lacking and seems so simple to implement…
I have a few things that I need to be able to set a delay for, ON 200ms then OFF and there is no way to do that without using brink or making a gpo script.
I’m using a pi though, I’m very new to programing, I can program a little in Arduino and would like to start using python on the pi, question - can I just write a python scrip to turn the button off after 200ms if its detected to be on? and how will the cayenne app react to it turning of will it try to turn it back on? any tips where I should start learning?
thanks for your time.
I’d start here:
Here is a project that uses MQTT via python on the Pi. It doesn’t have any buttons but you can easily modify to add them in. DHT11/DHT22 with Raspberry Pi
Thank you guys! I’ll try that over the next week and see how I Go, really appreciate the advice. ![]()
