Thank you in advance for taking the time to let us know about your Ideas. We truly value your input and discuss each Suggestion as a team. It would be most helpful if you could include a use case for your Idea (how it will solve a problem, or add to the usefulness of Cayenne as a proto-typing solution). Thanks!
Si potrebbe riprovare a mettere la schedulazione , timer e trigger
sarebbe un progetto interessante
oppure ancor meglio se creare un database mysql lite nel rasperry stesso che faccia da memoria eventi memoria stato e riportare allo stesso se abbiamo un balì out corrente
comunque Grazie per il Vostro impegno
we are getting the scheduler back in the next update. About trigger it is working fine on raspberry pi. what is the issue you are facing?
thank you for suggesting the idea.
