Hi, I need some help in building a salt water station that will measure temperature, electrical conductivity and dissolved oxygen. These three sensors will be hooked up on a tentacle t3 and on a raspberry pi 4b. I have scripts to read the data but i dont know how to use them in node red. Any help would be appreciate. Im using the atlas scientific sample script but when i run it i get a list with commands and responses, o type poll for example and i get the temperature data. What should i change in that script in order to just run it and get the data without the need of giving a command?
to send data to cayenne you can use GitHub - myDevicesIoT/Cayenne-MQTT-Python: Python Library for Cayenne MQTT API
