I changed the baud rate back from 9600 to 115200 using AT+UART_DEF=115200,8,1,0,0 comand, and upload a new code
Now, connect the MRC-522 to your arduino and upload this code rfid/DumpInfo.ino at master · miguelbalboa/rfid · GitHub
and see if you can read the rfid tags.
Now try this code:
This sketch uses the MFRC522 library ; see https://github.com/miguelbalboa/rfid
for further details and other examples.
NOTE: The library file MFRC522.h has a lot of useful info. Please read it.
This sketch show a simple locking mechanism using the RC522 RFID module.
Typical pin layout used:
MFRC522 Arduino Arduino Arduino Arduino Arduino
Reader/PCD Uno Mega Nano v3 Leonardo/Micro Pro Micro
Signal Pin Pin Pin Pin Pin Pin
RST/Reset RST 9 5 D9 RESET/ICSP-5 RST
SPI SS SDA(SS) 10 53 D10 10 10
SPI MOSI MOSI 11 / ICSP-4 51 D11 ICSP-4 16
SPI MISO MISO 12 / ICSP-1 50 D12 ICSP-1 14
SPI SCK SCK 13 / ICSP-3 52 D13 ICSP-3 15
#define CAYENNE_DEBUG
char ssid[] = "xxxx";
char wifiPassword[] = "xxxxx";
char username[] = "xxxxx";
char password[] = "xxxxx";
char clientID[] = "xxxxxx";
#include <SPI.h>
#include <MFRC522.h>
#include <EEPROM.h>
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
String read_rfid;
String ok_rfid_1 = "452b85ab";
String ok_rfid_2 = "8525fab";
String ok_rfid_3 = "7e287b25";
String ok_rfid_4 = "559acd65";
//String ok_rfid_2="ffffffff"; //add as many as you need.
unsigned long lastMillis = 0;
int a;
int b;
int c;
int d;
int EEaddress0 = 1;
int EEaddress2 = 4;
int EEaddress4 = 8;
int EEaddress6 = 12;/*
Initialize.
/*EEPROM.begin(32);
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
a = EEPROM.get(EEaddress0, a);
Serial.println(a);
b = EEPROM.get(EEaddress2, b);
Serial.println(b);
c = EEPROM.get(EEaddress4, c);
Serial.println(c);
d = EEPROM.get(EEaddress6, d);
Serial.println(d);
Serial.println("connected");*/
//pinMode(D4, OUTPUT);
Helper routine to dump a byte array as hex values to Serial.
void dump_byte_array(byte *buffer, byte bufferSize) {
read_rfid = "";
for (byte i = 0; i < bufferSize; i++) {
read_rfid = read_rfid + String(buffer[i], HEX);
void check1() {
a++;
Serial.println(a);
EEPROM.put(EEaddress0, a);
EEPROM.commit();
digitalWrite(D4, LOW);
delay(2000);
void check2() {
b++;
Serial.println(b);
EEPROM.put(EEaddress2, b);
EEPROM.commit();
delay(2000);
void check3() {
c++;
Serial.println(c);
EEPROM.put(EEaddress4, c);
EEPROM.commit();
delay(2000);
void check4() {
d++;
Serial.println(d);
EEPROM.put(EEaddress6, d);
EEPROM.commit();
delay(2000);
//digitalWrite(D4, HIGH);
//Cayenne.loop();
/*if (millis() - lastMillis > 10000) {
lastMillis = millis();
Cayenne.virtualWrite(0, a);
Cayenne.virtualWrite(1, b);
Cayenne.virtualWrite(2, c);
Cayenne.virtualWrite(3, d);
//Cayenne.luxWrite(2, 700);
Serial.println("reading");
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
if (read_rfid == ok_rfid_1) {
Serial.println("detected card");
//check1();
if (read_rfid == ok_rfid_2) {
//check2();
if (read_rfid == ok_rfid_3) {
// check3();
if (read_rfid == ok_rfid_4) {
//check4();
comment all the EEPROM lines out.
#include <SPI.h>
String read_rfid;
int a;
int b;
int c;
int d;
/*EEPROM.begin(32);
Serial.println(a);
Serial.println(b);
Serial.println(c);
Serial.println(d);
read_rfid = "";
//Cayenne.loop();
return;
return;
//check1();
//check2();
// check3();
//check4();
Did you change this to your rfid tag UID?
Then place your tag and check if it detects.
I’ve done it, replaced it with my UID, and the result is what I said
even when you placed your tag on it? can you share the entire code alongwith the your UID?
of course Test1.ino.txt (3.2 KB)
sorry, my mistake. try this code:
#include <SPI.h>
String read_rfid;
String ok_rfid_1 = "d9b89455";
String ok_rfid_2 = "97c7251b";
String ok_rfid_3 = "a733f41c";
int a;
int b;
int c;
int d;
mfrc522.PCD_Init();
read_rfid = "";
return;
return;
//check1();
//check2();
// check3();
//check4();
I’ve uploaded it, and it worked,
then how is the rfid scanner connected to the Cayenne dashboard? I have tried modifying the sketch, but the results are like this,
there seems to be an error when I try to modify it
try this code and see if it connects to cayenne:
#include <SPI.h>
char ssid[] = "wncry20%";
char wifiPassword[] = "nasigoren";
char username[] = "xxxx";
char password[] = "xxxx";
char clientID[] = "xxxx";
String read_rfid;
int a;
int b;
int c;
int d;
mfrc522.PCD_Init();
delay(500);
read_rfid = "";
//Serial.println("reading");
return;
return;
//Serial.println("detected card");
//check1();
// Serial.println("detected card");
//check2();
// check3();
//check4();
