I am trying to use sparkfun pHat along with environmental sensors on my raspberry pi 4, although weather data is displayed on the terminal, I could not get the data in to cayenne dashboard. I am running the following code to upload data from the sensors:
#!/usr/bin/env python3
# Example Code for Qwiic Kit for Raspberry Pi
# Qwiic Starter Kit Demo for Raspberry Pi
# Read data from the BME280, CCS811, and VCNL4040 proximity sensor. Then display
# the data on the screen, the Micro OLED, and send MQTT data to Cayenne.
# By: Michelle Shorter @ SparkFun Electronics
# Original Creation Date: May 29, 2019
# For the hookup instructions and kit go to:
# https://learn.sparkfun.com/tutorials/qwiic-kit-for-raspberry-pi-hookup-guide
# This code is beerware/beefware; if you see me (or any other SparkFun employee)
# at the local, and you've found our code helful, please buy us a beer/burger!
# Distributed as-is; no warranty is given
#Must download Qwiic Python Library - https://github.com/sparkfun/qwiic_py
from __future__ import print_function, division
import qwiic
import time
import sys
#These values are used to give BME280 and CCS811 some time to take samples
initialize=True
n=2
#MQTT Cayenne setup - you will need your own username, password and clientid
#To setup a Cayenne account go to https://mydevices.com/cayenne/signup/
username = "_____ENTER_MQTT_USERNAME____"
password = "_____ENTER_MQTT_PASSWORD____"
clientid = "_____ENTER_CAYENNE_CLIENTE_ID____"
mqttc = mqtt.Client(client_id="7ba5df90-9a79-11ea-b767-3f1a8f1211ba")
mqttc.username_pw_set("440e7680-98e6-11ea-a67f-15e30d90bbf4", password="c4f4d77c1cf5ffdc292c3a9b409c786c8e075fd6")
mqttc.loop_start()
#Qwiic Board define
prox = qwiic.QwiicProximity()
bme = qwiic.QwiicBme280()
ccs = qwiic.QwiicCcs811()
oled = qwiic.QwiicMicroOled()
#Begin statements
prox.begin()
bme.begin()
#ccs.begin()
oled.begin()
#Used for debugging CCS811
try:
ccs.begin()
except Exception as e:
print(e)
#Setup OLED
oled.clear(oled.ALL)
oled.display()
oled.set_font_type(1)
#set MQTT topics (we are not setting topics for everything)
topic_bme_temp = "v1/" + username + "/things/" + clientid + "/data/1"
topic_bme_hum = "v1/" + username + "/things/" + clientid + "/data/2"
topic_bme_pressure = "v1/" + username + "/things/" + clientid + "/data/3"
topic_bme_altitude = "v1/" + username + "/things/" + clientid + "/data/4"
topic_prox_proximity = "v1/" + username + "/things/" + clientid + "/data/5"
topic_prox_ambient = "v1/" + username + "/things/" + clientid + "/data/6"
topic_ccs_temp = "v1/" + username + "/things/" + clientid + "/data/7"
topic_ccs_tvoc = "v1/" + username + "/things/" + clientid + "/data/8"
topic_ccs_co2 = "v1/" + username + "/things/" + clientid + "/data/9"
#Loop runs until we force an exit or something breaks
while True:
try:
if initialize==True:
print ("Initializing: BME280 and CCS811 are taking samples before printing and publishing data!")
print (" ")
else:
#print ("Finished initializing")
n=1 #set n back to 1 to read sensor data once in loop
for n in range (0,n):
#print ("n = ", n) #used for debugging for loop
#Proximity Sensor variables - these are the available read functions
#There are additional functions not listed to set thresholds, current, and more
proximity = prox.get_proximity()
ambient = prox.get_ambient()
white = prox.get_white()
#close = prox.is_close()
#away = prox.is_away()
#light = prox.is_light()
#dark = prox.is_dark()
#id = prox.get_id()
#BME280 sensor variables
#reference pressure is available to read or set for altitude calculation
#referencePressure = bme.get_reference_pressure()
#bme.set_reference_pressure(referencePressure)
pressure = bme.get_reference_pressure() #in Pa
altitudem = bme.get_altitude_meters()
altitudef = bme.get_altitude_feet()
humidity = bme.read_humidity()
tempc = bme.get_temperature_celsius()
tempf = bme.get_temperature_fahrenheit()
dewc = bme.get_dewpoint_celsius()
dewf = bme.get_dewpoint_fahrenheit()
#CCS811 sensor variables
#ccsbaseline = get_baseline() #used for telling sensor what 'clean' air is
#set_baseline(ccsbaseline)
#error = ccs.check_status_error()
#data = ccs.data_available()
#app = ccs.app_valid()
#errorRegister = ccs.get_error_register()
#ccs.enable_interrupts()
#ccs.disable_interrupts()
#ccs.set_drive_mode(mode) #Mode0=Idle, Mode1=read every 1s, Mode2=read every 10s, Mode3=read every 60s, Mode4=RAW mode
#ccs.set_environmental_data(humidity,temperature)
ccs.read_algorithm_results() #updates the TVOC and CO2 values
tvoc = ccs.get_tvoc()
co2 = ccs.get_co2()
#Note:The following values are used when is a NTC thermistor attached to the CCS811 breakout board
#the environmental combo does not breakout the pins like the breakout board
#ccs.set_reference_resistance()
#ccs.read_ntc() #updates temp value
#ccstemp = ccs.get_temperature()
#ccsres = ccs.get_resistance()
#Give some time for the BME280 and CCS811 to initialize when starting up
time.sleep(10)
initialize=False
#printing time and some variables to the screen
#https://docs.python.org/3/library/time.html
#print (time.strftime("%a %b %d %Y %H:%M:%S", time.localtime())) #24-hour time
print (time.strftime("%a %b %d %Y %I:%M:%S%p", time.localtime())) #12-hour time
print ("BME Temperature %.1f C" %tempc)
print ("Humidity %.1f" %humidity)
print ("Pressure %.2f Pa" %pressure)
print ("Altitude %.2f ft" %altitudef)
print ("Altitude % 2f mt" %altitudem)
#print ("CCS Temperature %.1f F" %ccstemp)
print ("Distance %.2f " %proximity)
print ("Ambient Light %.2f" %ambient)
print ("TVOC %.2f" %tvoc)
print ("CO2 %.2f" %co2)
print (" ") #blank line for easier readability
#publishing data to Cayenne (we are not publishing everything)
mqttc.publish (topic_bme_temp, payload = tempc, retain = True)
mqttc.publish (topic_bme_hum, payload = humidity, retain = True)
mqttc.publish (topic_bme_pressure, payload = pressure, retain = True)
mqttc.publish (topic_bme_altitude, payload = altitudef, retain = True)
mqttc.publish (topic_prox_proximity, payload = proximity, retain = True)
mqttc.publish (topic_prox_ambient, payload = ambient, retain = True)
#mqttc.publish (topic_ccs_temp, payload = ccstemp, retain = True)
mqttc.publish (topic_ccs_tvoc, payload = tvoc, retain = True)
mqttc.publish (topic_ccs_co2, payload = co2, retain = True)
#displaying data to the OLED (we are only displaying a few things because of screen size)
#with font1 a y difference of 16 is good spacing for each line
#we are converting values to int before printing for space (and we don't really need better resolution)
oled.clear(oled.PAGE)
oled.set_cursor(0,0)
oled.print("Tmp:")
oled.print(int(tempc))
oled.print("C")
#oled.print(int(temc))
#oled.print("C")
oled.set_cursor(0,16)
oled.print("RH%:") #Relative Humidity
oled.print(int(humidity))
oled.set_cursor(0,32)
oled.print("hPa:") #hPa is a more typical output and helps with spacing
oled.print(int(pressure/100))
oled.display()
#delay (number of seconds) so we are not constantly displaying data and overwhelming devices
time.sleep(5)
#if we break things or exit then exit cleanly
mqttc.disconnect()
sys.exit()
