to subscribe to another device published data here is a code which i modified from @spacefolder code.
MQTT Raw Data to Cayenne Dashboard,
using the great Nick O'Leary's PubSubClient
(Arduino Client for MQTT, https://github.com/knolleary/pubsubclient)
What does it do?
This sketch will attempt to connect to Cayenne MQTT server via Wifi,
subscribe to a "dashboard button" topic, to turn on/off the esp8266 built in led.
Also it will publish temperature readings from a Dallas DS18b20 digital temperature sensor.
In a near future, the esp8266 (NodeMCU v2) should act as a smart thermostat, controlling my central heater/boiler.
It should be possible to remotely check ambient temperature and boiler status using
Cayenne Dashboard and turn the heater on/off (in case I left home in a hurry!, etc.)
Inspired in several tutorials and sketches mashed up, mainly..
Andreas Spiess https://github.com/SensorsIot
Terry King terry@yourduino.com
Markus Ulsass https://github.com/markbeee
Marc / spacefolder
// ---------- INLCUDE LIBRARIES ----------
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// ---------- DEFINE CONSTANT VALUES ----------
#define MQTT_SERVER "mqtt.mydevices.com"
#define MQTT_SERVERPORT 1883
#define MQTT_USERNAME ""
#define MQTT_PASSWORD ""
#define CLIENT_ID ""
#define CLIENT_ID_SUB ""
#define MQTT_TOPIC_BTN_ONOFF "v1/" MQTT_USERNAME "/things/" CLIENT_ID_SUB "/data/2"
// ---------- INITIALIZE INSTANCES ----------
WiFiClient espClient; // Creates a client instance for the PubSubClient
PubSubClient client(espClient);
// ---------- DEFINE VARIABLES ----------
const char* ssid = ""; // WLAN-SSID (WiFi router)
const char* password = ""; // WLAN Password
// Define a datatype to store the mqtt message, up to 50 bytes.
char msg[50]; // 50 BYTES QUIZAS SEA MUCHO AL GAS, pero bueh
// -------------------- SETUP -------------------
// Initialize serial monitor for debugging purposes.
Serial.println("DEBUG: Entering setup ");
// Attempt to connect to WiFi.
WiFi.begin(ssid, password);
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println(""); // Faltaria agregar que muestre el ip si no es estatico
Serial.println("WiFi connected");
// Initialize MQTT PubSub Library
client.setServer(MQTT_SERVER, MQTT_SERVERPORT);
// Function called in case of an incomming mqtt message from Cayenne Dashboard
// (In this case is the dashboard button to turn on/off the heater)
client.setCallback(mqttCallback);
Serial.println("DEBUG: Setup Done! ");
// -------------------- LOOOP -------------------
// Check if the esp8266 is connected to the mqtt server.
if (!client.connected()) {
reconnect();
// If connected, perform PubSubClient housekeeping function.
client.loop();
delay(500);
// ------------------------------ OTHER FUNCTIONS
// Function that attempts to reconnect to the mqtt server.
void reconnect() {
// If esp8266 is disconnected from the mqtt server, try to reconnect.
// (*** I still need to think what wil happen to the boiler if connection is lost ***)
while (!client.connected()) {
Serial.print("DEBUG: Attempting MQTT connection...");
if (client.connect(CLIENT_ID, MQTT_USERNAME, MQTT_PASSWORD)) {
Serial.println("connected");
// Once connected, resubscribe to the Dashboard on/off button topic.
client.subscribe(MQTT_TOPIC_BTN_ONOFF);
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
Serial.println("DEBUG: Quiting reconnect loop ");
// Function to intercept MQTT messages
void mqttCallback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
// Show the received message "stream" in the serial monitor.
Serial.print((char)payload[i]);
Serial.println();
// Delay for debugging purposes. If a message arrives from Cayenne, the terminal feed pauses 5'.
delay(5000);
