Sharp GP2Y1010AU0F - dust sensor
Codes for different boards and shields.
All codes only work with MQTT.
Arduino_Industrial_101.txt (1.2 KB)
EthernetShieldW5200.txt (2.0 KB)
ArduinoYun.txt (1.5 KB)
EthernetShieldW5100.txt (2.0 KB)
EthernetShieldW5500.txt (2.0 KB)
ManualConnection.txt (2.9 KB)
WiFiShield.txt (2.1 KB)
WiFi101Shield.txt (2.1 KB)
Sample from the Cayenne Dashboard.
I tried to use the WiFiShield example for the Sharp GP2Y1010AU0F in combination with a Wemos D1 mini but I run into compile errors.
In file included from C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoDefines.h:127:0,
                 from C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h:21,
                 from C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTWiFiClient.h:21,
                 from C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTWiFi.h:25,
                 from C:\Users\Marco\Documents\Arduino\GP2YDustWemosCayenne\GP2YDustWemosCayenne.ino:5:
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/DetectDevice.h:227:10: warning: #warning "Cannot detect board type" [-Wcpp]
In file included from C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/CayenneMQTTClient.h:24:0,
                 from C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMessage.h:32,
                 from C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneHandlers.h:29,
                 from C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoDefines.h:128,
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:328:30: warning: type qualifiers ignored on function return type [-Wignored-qualifiers]
      const size_t getCount() const {
In file included from C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTWiFiClient.h:21:0,
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h: In member function 'void CayenneArduinoMQTTClient::connect()':
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h:59:63: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h: At global scope:
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h:292:7: warning: unused parameter 'channel' [-Wunused-parameter]
  void syncVirtual(int channel)
In file included from C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTWiFi.h:25:0,
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTWiFiClient.h: In member function 'void CayenneMQTTWiFiClient::begin(const char*, const char*, const char*, const char*, const char*)':
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTWiFiClient.h:49:33: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
    WiFi.begin(ssid, wifiPassword);
In file included from C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTWiFi.h:23:0,
C:\Users\Marco\Documents\Arduino\libraries\WiFi\src/WiFi.h:79:9: error:   initializing argument 1 of 'int WiFiClass::begin(char*, const char*)' [-fpermissive]
     int begin(char* ssid, const char *passphrase);
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTWiFiClient.h:52:19: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
    WiFi.begin(ssid);
C:\Users\Marco\Documents\Arduino\libraries\WiFi\src/WiFi.h:60:9: error:   initializing argument 1 of 'int WiFiClass::begin(char*)' [-fpermissive]
     int begin(char* ssid);
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTWiFiClient.h:41:7: warning: unused variable 'status' [-Wunused-variable]
   int status = WL_IDLE_STATUS;
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h: In instantiation of 'static void CayenneArduinoMQTTClient::publishData(CayenneTopic, unsigned int, const T&, const char*, const char*) [with T = const __FlashStringHelper*; CayenneTopic = CayenneTopic]':
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h:125:66:   required from here
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h:333:3: error: call of overloaded 'add(const char*&, const __FlashStringHelper* const&)' is ambiguous
   values.add(subkey, data);
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h:333:3: note: candidates are:
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:106:15: note: void CayenneMQTT::DataArray<BUFFER_SIZE, MAX_VALUES>::add(const char*, int) [with int BUFFER_SIZE = 64; int MAX_VALUES = 4] <near match>
   inline void add(const char* unit, const int value) {
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:106:15: note:   no known conversion for argument 2 from 'const __FlashStringHelper* const' to 'int'
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:121:15: note: void CayenneMQTT::DataArray<BUFFER_SIZE, MAX_VALUES>::add(const char*, unsigned int) [with int BUFFER_SIZE = 64; int MAX_VALUES = 4] <near match>
   inline void add(const char* unit, const unsigned int value) {
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:121:15: note:   no known conversion for argument 2 from 'const __FlashStringHelper* const' to 'unsigned int'
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:136:15: note: void CayenneMQTT::DataArray<BUFFER_SIZE, MAX_VALUES>::add(const char*, long int) [with int BUFFER_SIZE = 64; int MAX_VALUES = 4] <near match>
   inline void add(const char* unit, const long value) {
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:136:15: note:   no known conversion for argument 2 from 'const __FlashStringHelper* const' to 'long int'
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:151:15: note: void CayenneMQTT::DataArray<BUFFER_SIZE, MAX_VALUES>::add(const char*, long unsigned int) [with int BUFFER_SIZE = 64; int MAX_VALUES = 4] <near match>
   inline void add(const char* unit, const unsigned long value) {
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:151:15: note:   no known conversion for argument 2 from 'const __FlashStringHelper* const' to 'long unsigned int'
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h: In instantiation of 'static void CayenneArduinoMQTTClient::publishData(CayenneTopic, unsigned int, const T&, const __FlashStringHelper*, const __FlashStringHelper*) [with T = float; CayenneTopic = CayenneTopic]':
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h:159:52:   required from 'void CayenneArduinoMQTTClient::virtualWrite(unsigned int, const T&, const __FlashStringHelper*, const __FlashStringHelper*) [with T = float]'
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h:221:68:   required from here
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h:349:3: error: no matching function for call to 'CayenneMQTT::DataArray<>::add(const __FlashStringHelper*&, const float&)'
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h:349:3: note: candidates are:
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:65:8: note: void CayenneMQTT::DataArray<BUFFER_SIZE, MAX_VALUES>::add(const char*, const char*, bool, bool) [with int BUFFER_SIZE = 64; int MAX_VALUES = 4]
   void add(const char* unit, const char* value, bool unitInFlash = false, bool valueInFlash = false) {
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:65:8: note:   no known conversion for argument 1 from 'const __FlashStringHelper*' to 'const char*'
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:106:15: note:   no known conversion for argument 1 from 'const __FlashStringHelper*' to 'const char*'
Multiple libraries were found for "WiFi.h"
 Used: C:\Users\Marco\Documents\Arduino\libraries\WiFi
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:121:15: note:   no known conversion for argument 1 from 'const __FlashStringHelper*' to 'const char*'
 Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:136:15: note:   no known conversion for argument 1 from 'const __FlashStringHelper*' to 'const char*'
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:151:15: note:   no known conversion for argument 1 from 'const __FlashStringHelper*' to 'const char*'
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:190:15: note: void CayenneMQTT::DataArray<BUFFER_SIZE, MAX_VALUES>::add(const char*, float) [with int BUFFER_SIZE = 64; int MAX_VALUES = 4]
   inline void add(const char* unit, const float value) {
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:190:15: note:   no known conversion for argument 1 from 'const __FlashStringHelper*' to 'const char*'
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:201:15: note: void CayenneMQTT::DataArray<BUFFER_SIZE, MAX_VALUES>::add(const char*, double) [with int BUFFER_SIZE = 64; int MAX_VALUES = 4]
   inline void add(const char* unit, const double value) {
C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTClient/../CayenneUtils/CayenneDataArray.h:201:15: note:   no known conversion for argument 1 from 'const __FlashStringHelper*' to 'const char*'
Using library CayenneMQTT at version 1.0.1 in folder: C:\Users\Marco\Documents\Arduino\libraries\CayenneMQTT
Using library WiFi at version 1.2.6 in folder: C:\Users\Marco\Documents\Arduino\libraries\WiFi
Using library SPI at version 1.0 in folder: C:\Users\Marco\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI
exit status 1
Error compiling for board WeMos D1 R2 & mini.
Is this the right example for this tis combination?
Well I guess not…:wink:
So, my question now: is there a example code for the Sharp dust sensor and Wemos D1 mini combination?
Thank you!
you need to use this connection example code https://github.com/myDevicesIoT/Cayenne-MQTT-Arduino/blob/feature/gsm-support/examples/Connections/ESP8266/ESP8266.ino and add the code of Sharp GP2Y1010AU0F into it.
Best wishes for 2019 shramik and thanks for the support.
I can upload the code to my device but the serial monitor gives:
[7262] Connecting to mqtt.mydevices.com:1883
[14156] Network connect failed
[21231] Network connect failed
[29405] Network connect failed
[36580] Network connect failed
[44654] Network connect failed
My first thought was check the router but I can’t see that it’s blocking port 1883?
Happy new year @marco_rudolph
possibility is some network firewall is blocking traffic to mqtt.mydevices.com or port 1883.
Yes, although I have not found it yet, it has to be something in my router. If set my mobile as an AP I get a connect immediately according to the serial monitor.
In Cayenne I do not yet see a widget but still the message:
Waiting for board to connect …
add #define CAYENNE_DEBUG in your code and share the serial monitor output here.
[8053] Publish: topic 1, channel 0, value 8053, subkey , key
[8193] Publish: topic 1, channel 1, value -96.879, subkey mg, key pm
[9325] Publish: topic 1, channel 0, value 9325, subkey , key
[9482] Publish: topic 1, channel 1, value -96.099, subkey mg, key pm
[10616] Publish: topic 1, channel 0, value 10616, subkey , key
[10764] Publish: topic 1, channel 1, value -96.099, subkey mg, key pm
[11897] Publish: topic 1, channel 0, value 11897, subkey , key
[12046] Publish: topic 1, channel 1, value -96.879, subkey mg, key pm
[13177] Publish: topic 1, channel 0, value 13177, subkey , key
[13349] Publish: topic 1, channel 1, value -96.099, subkey mg, key pm
[14541] Publish: topic 1, channel 0, value 14541, subkey , key
[14736] Publish: topic 1, channel 1, value -96.099, subkey mg, key pm
[15908] Publish: topic 1, channel 0, value 15908, subkey , key
[16056] Publish: topic 1, channel 1, value -96.099, subkey mg, key pm
[17312] Publish: topic 1, channel 0, value 17311, subkey , key
[17530] Publish: topic 1, channel 1, value -96.879, subkey mg, key pm
[18728] Connection ok
[18728] Publish: topic 1, channel 0, value 18728, subkey , key
[19676] Publish: topic 1, channel 1, value -96.879, subkey mg, key pm
[20816] Publish: topic 1, channel 0, value 20816, subkey , key
[20974] Publish: topic 1, channel 1, value -96.879, subkey mg, key pm
[22106] Publish: topic 1, channel 0, value 22106, subkey , key
[22257] Publish: topic 1, channel 1, value -96.879, subkey mg, key pm
[23390] Publish: topic 1, channel 0, value 23389, subkey , key
[23533] Publish: topic 1, channel 1, value -96.879, subkey mg, key pm
[24665] Publish: topic 1, channel 0, value 24665, subkey , key
[24818] Publish: topic 1, channel 1, value -96.879, subkey mg, key pm
[25945] Publish: topic 1, channel 0, value 25945, subkey , key
[26097] Publish: topic 1, channel 1, value -96.879, subkey mg, key pm
[27227] Publish: topic 1, channel 0, value 27227, subkey , key
[27378] Publish: topic 1, channel 1, value -96.879, subkey mg, key pm
[28506] Publish: topic 1, channel 0, value 28505, subkey , key
[28716] Publish: topic 1, channel 1, value -94.538, subkey mg, key pm
[29921] Connection ok
// Publish data every 1 seconds (1000 milliseconds). Change this value to publish at a different interval.
lastMillis = millis();
//Write data to Cayenne here. This example just sends the current uptime in milliseconds
I’m a bit further. I have removed this section above and now you can see the widget :grin:… now find out why I get a negative value
Here is my code:
char ssid[] = "******";
char wifiPassword[] = "******";
char username[] = "************";
char password[] = "***********";
char clientID[] = "***********";
unsigned long lastMillis = 0;
int measuringPin = A0;
int ledPin = 2;
const int timeMeasuring = 280;
const int timeStabilization = 40;
const int timeSleep = 9680;
float voltageAnalog = 0;
float voltageConversion = 0;
float dustiness = 0;
  pinMode(ledPin,OUTPUT);
     digitalWrite(ledPin,LOW);
    delayMicroseconds(timeMeasuring);
    voltageAnalog = analogRead(measuringPin);
    delayMicroseconds(timeStabilization);
    digitalWrite(ledPin,HIGH);
    delayMicroseconds(timeSleep);
    voltageConversion = voltageAnalog * (4.7 / 1024.0);  //Voltage on 5V pin on Arduino, My voltage is 4.7 V
    dustiness = (0.17 * voltageConversion - 0.1)*1000;
    Cayenne.virtualWrite(1, dustiness, "pm", "mg");
you need to come a bit back, as you will hit the rate limit. Have a look at this topic Sending MQTT messages within rate limits
follow this tutorial and first get the correct reading from the sensor Wemos and dust sensor example - esp8266 learning
@shramik_salgaonkar, that’s it!
I’ve modified the code and widgets and now I see the values according to the Sharp GP2Y1010AU0F Dust density chart in my dashboard.
Here is the final code for the Sharp GP2Y1010AU0F with Wemos D1 MIni and CayenneMQtt:
char wifiPassword[] = "*****";
char username[] = "*************";   //Cayenne MQTT Username
char password[] = "*************";   // Cayenne MQTT PassWord
char clientID[] = "*************";      // Client ID
int ledPin = D2;
float voltsMeasured = 0;
float calcVoltage = 0;
float dustDensity = 0;
  pinMode(ledPin, OUTPUT);
  if (millis() - lastMillis > 5000)
    digitalWrite(ledPin, LOW);
    delayMicroseconds(280);
    voltsMeasured = analogRead(measuringPin);
    delayMicroseconds(40);
    digitalWrite(ledPin, HIGH);
    delayMicroseconds(9680);
    calcVoltage = voltsMeasured * (4.7 / 1024.0); //Voltage on 5V pin on Arduino, My voltage is 4.7 V
    dustDensity = (0.17 * calcVoltage - 0.1);
    Cayenne.virtualWrite(0,calcVoltage, "V");
    Cayenne.virtualWrite(1, dustDensity, "mg");
No Smoke
Full Smoke
Thanks for that push in the right direction :grinning:
Glad to hear to hear it is working and thanks for sharing the code.
Just for fun, I’ve added a RGB Led and a DHT temperature/humidity sensor to this setup…maybe a basic recipe as inspiration for someone else…:grinning:
the code:
#include <DHT.h>
#define DHTTYPE DHT11
#define DHTPIN D5 //GPIO 14 or D5, D6 (gpio12) or D7 (gpio13)
DHT dht(DHTPIN, DHTTYPE); //Initialize DHT sensor
// GP2Y014AU0F Dust sensor
int ledPin = D2;
//RGB
const int red = D6;
const int green = D7;
const int blue = D8;
  // DHT
  Serial.begin(115200);
  Serial.println("DHTxx test!");
  dht.begin();
  //RGB
  pinMode(red, OUTPUT);
  pinMode(green, OUTPUT);
  pinMode(blue, OUTPUT);
  // Wait a few seconds between measurements.
  delay(5000);
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
  if (isnan(h) || isnan(t) || isnan(f))
    Serial.println("Failed to read from DHT sensor!");
    return;
  // Compute heat index in Fahrenheit (the default)
  // float hif = dht.computeHeatIndex(f, h);
  // Compute heat index in Celsius (isFahreheit = false)
  // float hic = dht.computeHeatIndex(t, h, false);
//For testing
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print(t);
  Serial.print(" C\t");
  // Serial.print(f);
  // Serial.print(" *F\t");
  // Serial.print("Heat index: ");
  // Serial.print(hic);
  // Serial.print(" *C ");
  // Serial.print(hif);
  // Serial.println(" *F");
  digitalWrite(red, LOW);
  digitalWrite(green, LOW);
  digitalWrite(blue, LOW);
  // Channel 4.
  if (t < 16)
    digitalWrite(blue, HIGH);
    Cayenne.virtualWrite(4, HIGH, "digital_sensor", "d");
  else
    Cayenne.virtualWrite(4, LOW, "digital_sensor", "d");
  // Channel 5.
  if ((t > 16 && t < 22) && (calcVoltage <= 1.0))
    digitalWrite(green, HIGH);
    Cayenne.virtualWrite(5, HIGH, "digital_sensor", "d");
    else
    Cayenne.virtualWrite(5, LOW, "digital_sensor", "d");
  // Channel 6.
  if ((t > 25) || (calcVoltage > 1.5))
    digitalWrite(red, HIGH);
    Cayenne.virtualWrite(6, HIGH, "digital_sensor", "d");
    else
    Cayenne.virtualWrite(6, LOW, "digital_sensor", "d");
    Serial.print("Output Voltage: ");
    Serial.print(calcVoltage);
    Serial.print(" V\t");
    Serial.print("Dust density: ");
    Serial.print(dustDensity);
    Serial.print(" mg/m3\r");
    Serial.println();
    calcVoltage = voltsMeasured * (4.7 / 1024.0); //Voltage on 5V pin on Arduino, Voltage Wemos D1 Mini is 4.7 V
    Cayenne.virtualWrite(0, calcVoltage, "voltage", "v");
    Cayenne.virtualWrite(1, dustDensity, "pm", "mg");
    Cayenne.virtualWrite(2, h, "rel_hum", "p");
    Cayenne.virtualWrite(3, t, "temp", "c");
    //Cayenne.virtualWrite(4, blue, "digital_sensor", "d");
    //Cayenne.virtualWrite(5, green, "digital_sensor", "d");
    //Cayenne.virtualWrite(6, red, "digital_sensor", "d");
thanks for sharing @marco_rudolph.
Nice
