Just to clarify then - the only way to see the pins is to watch as they are generated?
Can I change the characteristics of the pins, or add extra metadata to each point?
Thanks muchly. Steve
yes. when the data is published the map widget shows the point. But this widget is not fully supported for non-lora device.
