Hi Everybody,
I followed this tutorial
I have chosen ESP8266 hardware as the ESP8266 is the only one that is shown on in the choose hardwae-section
I have filled in all the credentials by careful copy & paste from the the according setup-website
https://cayenne.mydevices.com/cayenne/dashboard/first-visit/esp8266/pending/…
I uploaded this code below
This example shows how to connect to Cayenne using an ESP32 and send/receive sample data.
Steps:
1. If you have not already installed the ESP32 Board Package install it using the instructions here: https://github.com/espressif/arduino-esp32/blob/master/README.md#installation-instructions.
2. Select your ESP32 board from the Tools menu.
//#define CAYENNE_DEBUG
#include <CayenneMQTTESP32.h>
//#include <F:\MyPortable-PRgs\arduino1.8.13\portable\sketchbook\libraries\Cayenne-MQTT-ESP-master\src\CayenneMQTTESP32.h>;
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
Serial.begin(115200);
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
of course with all the carefully copy & pasted credentials
but the message stays at “Waiting for board to connect”
As you can see here
The tutorial shows a last point:
Step 9
Once uploaded, temporary widgets for the channel 0 should now show up in the Cayenne Dashboard. You can make them permanent by clicking the plus sign.
But there is no screenshot or description how to a reach the Cayenne Dashboard.
So what additional steps do I have to make or what have I done wrong that it is not working yet?
best regards Stefan
