I am new to Cayenne and am having problems connecting my ESP32 to the dashboard. I have followed the steps and downloaded the code and put in the correct MQTTusername, MQTTpassword, and clientID for connecting to the broker. The wifi does connect from my ESP32 but I just get a loading screen on the dashboard after the code is uploaded. Attached is my code, serial monitor, and dashboard.
#define CAYENNE_DEBUG
#include <CayenneMQTTESP32.h>
char ssid[] = "ssid";
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
I tried to connect my esp32 , esp8266 and both connected successfully. can you try connecting to cayenne using telnet mqtt.mydevices.com 1883 in your pc terminal. some firewall maybe be blocking.
Cayenne Light Switch Example
This sketch shows how to set up a Light Switch with Cayenne.
Steps:
1. In the Cayenne Dashboard add a new Light Switch Widget.
2. Select a virtual channel number for the widget.
3. Set the VIRTUAL_CHANNEL value below to virtual channel you selected.
4. Attach the negative leg of an LED to ground and the other leg to the selected digital pin.
Schematic:
[Ground] -- [LED] -- [Resistor] -- [Digital Pin]
5. Set the ACTUATOR_PIN value below to the pin number you used when connecting your LED.
6. Set the Cayenne authentication info to match the authentication info from the Dashboard.
7. Compile and upload this sketch.
8. Once the Arduino connects to the Dashboard you can use the widget button to turn the LED on and off.
char ssid[] = "XXX";
char wifiPassword[] = "XXX";
char username[] = "";
char password[] = "";
char clientID[] = "";
#define VIRTUAL_CHANNEL 1
#define ACTUATOR_PIN 4 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
Serial.begin(115200);
CAYENNE_IN(VIRTUAL_CHANNEL)
int value = getValue.asInt();
CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL, ACTUATOR_PIN, value);
Strange thing is that yesterday with another weemos D1 It worked well (and still working well with this D1) but it seems impossible to connect a new one
