There are a few bugs with temperatures that need to be fixed. Since you are using an “Arduino” you can set up a generic analog input as a virtual pin and send the values to it. This will display the number exactly as you send it. Here is an example Battery Powered ESP8266 Temperature/Humidity Monitor with DHT11
