follow this guide and get your esp connected to cayenne Cayenne MQTT and Standalone ESP8266 ESP-01 - myDevices and then add the code to control the relay.
Thanks so much!
Hi again. Could you help me with the soil moisture sensor, I mean with the code. Thanks.
which soil moisture sensor are you using?
I’m using this ones.
Code:
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "----";
char password[] = "";
char clientID[] = "----";
#define EspSerial Serial
#define SENSOR_PIN1 A0
#define VIRTUAL_CHANNEL1 1
#define SENSOR_PIN2 A2
#define VIRTUAL_CHANNEL2 2
ESP8266 wifi(&EspSerial);
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
CAYENNE_OUT(VIRTUAL_CHANNEL)
Cayenne.virtualWrite(VIRTUAL_CHANNEL1, analogRead(SENSOR_PIN1));
Cayenne.virtualWrite(VIRTUAL_CHANNEL2, analogRead(SENSOR_PIN2));
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
for the first time everything was working, but on the next day, after I play a little bit with widgets, its stop working. I delete an Arduino and add it again, done everything from the very beginning, but it doesn’t help.
can you uncomment this line in your code #define CAYENNE_DEBUG
and check the issue in your serial monitor.
AT
[1529] ESP is not responding
AT
ATE0
AT+CIPMUX=1
AT+CWMODE?
AT+CWJAP=“BEIREL 6354”,“75288437kh”
[8094] Connected to WiFi
[8095] Connecting to mqtt.mydevices.com:1883
AT+CIPSTART=1,“TCP”,“mqtt.mydevices.com”,1883
AT+CIPSEND=1,40
⸮MQIsdp⸮<$d06efc20-6116-11e9-9dd7AT+CIPSEND=1,40
-93e53f1934d3$291ec810-488a-11e8-bf56-dAT+CIPSEND=1,40
b14f0c2b326(0e737ffa31e6de40bdc7958fd08AT+CIPSEND=1,13
2af113f3c1a4f[8951] Connected
AT+CIPSEND=1,40
⸮^Yv1/291ec810-488a-11e8-bf56-db14f0cAT+CIPSEND=1,40
2b326/things/d06efc20-6116-11e9-9dd7-93eAT+CIPSEND=1,16
53f1934d3/cmd/+[9529] Publish: topic 4, channel 65534, value Arduino Uno, subkey , key
AT+CIPSEND=1,40
1j]v1/291ec810-488a-11e8-bf56-db14f0c2bAT+CIPSEND=1,40
326/things/d06efc20-6116-11e9-9dd7-93e53AT+CIPSEND=1,28
f1934d3/sys/modelArduino Uno[10061] Publish: topic 6, channel 65534, value ATmega328P, subkey , key
AT+CIPSEND=1,40
1mav1/291ec810-488a-11e8-bf56-db14f0c2bAT+CIPSEND=1,40
326/things/d06efc20-6116-11e9-9dd7-93e53AT+CIPSEND=1,31
f1934d3/sys/cpu/modelATmega328P[10544] Publish: topic 7, channel 65534, value 16000000, subkey , key
AT+CIPSEND=1,40
1kav1/291ec810-488a-11e8-bf56-db14f0c2bAT+CIPSEND=1,40
326/things/d06efc20-6116-11e9-9dd7-93e53AT+CIPSEND=1,29
f1934d3/sys/cpu/speed16000000[11027] Publish: topic 5, channel 65534, value 1.3.0, subkey , key
AT+CIPSEND=1,40
1f_v1/291ec810-488a-11e8-bf56-db14f0c2bAT+CIPSEND=1,40
326/things/d06efc20-6116-11e9-9dd7-93e53AT+CIPSEND=1,24
f1934d3/sys/version1.3.0[11508] Publish: topic 8, channel 65534, value ESP8266Shield, subkey , key
[11575] Publish: topic 1, channel 0, value 11575, subkey , key
AT+CIPSEND=1,40
1aZv1/291ec810-488a-11e8-bf56-db14f0c2bAT+CIPSEND=1,40
326/things/d06efc20-6116-11e9-9dd7-93e53AT+CIPSEND=1,19
f1934d3/data/011575[21547] Connection ok
[26579] Publish: topic 1, channel 0, value 26579, subkey , key
AT+CIPSEND=1,40
f1934d3/data/026579[31551] Connection ok
[41552] Connection ok
[41585] Publish: topic 1, channel 0, value 41585, subkey , key
AT+CIPSEND=1,40
f1934d3/data/041585
this one?
are you using this board?
No
I’m using Arduino Uno and ESP8266 module
the arduino UNO and esp8266 shield code is quite unstable as there is only one serial on uno. while this code is made for arduino mega.
from the serial monitor it looks like connecting but sending data on only channel 1. so can you try making this small change:
wow it’s working
but why?
you were calling the CAYENNE_OUT
function wrongly.
Ok.
Next problem: when I reboot the page, sensor shows value until the “0” and “2” channels pop up, but on my phone it shows all the time
what do mean by this. can you provide a screenshot of this.
you need to add the widgets to the dashboard by clicking on the + on the widgets.
