I add a second sensor and add 0 channel widget, but now, channel 2 is working, show measurements all the time, but channel 1 stop showing after a several seconds
i did not understand the above. is it working as you need it or is there still an issue.
Steps:
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "----";
char password[] = "";
char clientID[] = "----";
#define EspSerial Serial
#define SENSOR_PIN1 A0
#define VIRTUAL_CHANNEL1 1
#define SENSOR_PIN2 A2
#define VIRTUAL_CHANNEL2 2
ESP8266 wifi(&EspSerial);
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
CAYENNE_OUT_DEFAULT()
Cayenne.virtualWrite(VIRTUAL_CHANNEL1, analogRead(SENSOR_PIN1));
Cayenne.virtualWrite(VIRTUAL_CHANNEL2, analogRead(SENSOR_PIN2));
CAYENNE_IN_DEFAULT()
the code looks okay. can you share the serial monitor output.
⸮a⸮⸮⸮⸮Ո$⸮⸮⸮⸮AT
ATE0
AT+CIPMUX=1
[1551] Failed to enable MUX
AT+CWMODE?
AT+CWJAP=“BEIREL 6354”,“75288437kh”
[4585] Connected to WiFi
[4585] Connecting to mqtt.mydevices.com:1883
AT+CIPSTART=1,“TCP”,“mqtt.mydevices.com”,1883
AT+CIPSEND=1,40
⸮MQIsdp⸮<$d06efc20-6116-11e9-9dd7AT+CIPSEND=1,40
-93e53f1934d3$291ec810-488a-11e8-bf56-dAT+CIPSEND=1,40
b14f0c2b326(0e737ffa31e6de40bdc7958fd08AT+CIPSEND=1,13
2af113f3c1a4f[5504] Connected
AT+CIPSEND=1,40
⸮^Yv1/291ec810-488a-11e8-bf56-db14f0cAT+CIPSEND=1,40
2b326/things/d06efc20-6116-11e9-9dd7-93eAT+CIPSEND=1,16
53f1934d3/cmd/+[6082] Publish: topic 4, channel 65534, value Arduino Uno, subkey , key
AT+CIPSEND=1,40
1j]v1/291ec810-488a-11e8-bf56-db14f0c2bAT+CIPSEND=1,40
326/things/d06efc20-6116-11e9-9dd7-93e53AT+CIPSEND=1,28
f1934d3/sys/modelArduino Uno[6606] Publish: topic 6, channel 65534, value ATmega328P, subkey , key
AT+CIPSEND=1,40
1mav1/291ec810-488a-11e8-bf56-db14f0c2bAT+CIPSEND=1,40
326/things/d06efc20-6116-11e9-9dd7-93e53AT+CIPSEND=1,31
f1934d3/sys/cpu/modelATmega328P[7088] Publish: topic 7, channel 65534, value 16000000, subkey , key
AT+CIPSEND=1,40
1kav1/291ec810-488a-11e8-bf56-db14f0c2bAT+CIPSEND=1,40
326/things/d06efc20-6116-11e9-9dd7-93e53AT+CIPSEND=1,29
f1934d3/sys/cpu/speed16000000[7565] Publish: topic 5, channel 65534, value 1.3.0, subkey , key
AT+CIPSEND=1,40
1f_v1/291ec810-488a-11e8-bf56-db14f0c2bAT+CIPSEND=1,40
326/things/d06efc20-6116-11e9-9dd7-93e53AT+CIPSEND=1,24
f1934d3/sys/version1.3.0[8060] Publish: topic 8, channel 65534, value ESP8266Shield, subkey , key
[8128] Publish: topic 1, channel 0, value 8128, subkey , key
AT+CIPSEND=1,40
1`Zv1/291ec810-488a-11e8-bf56-db14f0c2bAT+CIPSEND=1,40
326/things/d06efc20-6116-11e9-9dd7-93e53AT+CIPSEND=1,18
f1934d3/data/08128[8604] Publish: topic 1, channel 1, value 599, subkey , key
AT+CIPSEND=1,40
1_Zv1/291ec810-488a-11e8-bf56-db14f0c2bAT+CIPSEND=1,40
326/things/d06efc20-6116-11e9-9dd7-93e53AT+CIPSEND=1,17
f1934d3/data/1599[9080] Publish: topic 1, channel 2, value 593, subkey , key
AT+CIPSEND=1,40
f1934d3/data/2593[18108] Connection ok
[23140] Publish: topic 1, channel 0, value 23140, subkey , key
AT+CIPSEND=1,40
1aZv1/291ec810-488a-11e8-bf56-db14f0c2bAT+CIPSEND=1,40
326/things/d06efc20-6116-11e9-9dd7-93e53AT+CIPSEND=1,19
f1934d3/data/023140[23882] Publish: topic 1, channel 1, value 598, subkey , key
AT+CIPSEND=1,40
f1934d3/data/1598[24554] Publish: topic 1, channel 2, value 593, subkey , key
AT+CIPSEND=1,40
f1934d3/data/2593[28130] Connection ok
check here all channel 0,1 and 2 are sending data. I would suggest deleting all the widgets and let them repopulate automatically. then click on + to add them.
ok I will try
Great! everything is fine now.
what is Channel 0? could I delete it?
is it this one? its just counting milliseconds
you can remove it. it uploads the uptime in millis()
Ok thanks.
how could I adjust the refreshing time?
have a look at this topic Sending MQTT messages within rate limits
Thank you so much!
Hi. This pictograms on my phone are “soil moisture”. Do you know when will be an update of the app to solve this problem? Thanks
what do you mean by this? can you share a screenshot.
the icon is not yet supported on mobile app. you can select other icon which is supported on both platform.
Ok. Thanks. Have a good day
Hi. Again, I have a problem with disconnecting, it goes offline every time.
code:
#include <DHT.h>
char ssid[] = "";
char username[] = "";
char clientID[] = "";
#define SENSOR_PIN2 A1
#define SENSOR_PIN3 A2
#define VIRTUAL_CHANNEL3 3
#define SENSOR_PIN4 A3
#define VIRTUAL_CHANNEL4 4
#define SENSOR_PIN5 A4
#define VIRTUAL_CHANNEL5 5
#define SENSOR_PIN6 A5
#define VIRTUAL_CHANNEL6 6
#define DHTPIN 2
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
#define TEMPERATURE_VIRTUAL_CHANNEL 7
#define HUMIDITY_VIRTUAL_CHANNEL 8
DHT dht(DHTPIN, DHTTYPE); // Initialize DHT sensor.
delay(10);
delay(10);
dht.begin();
CAYENNE_OUT(TEMPERATURE_VIRTUAL_CHANNEL)
Cayenne.virtualWrite(TEMPERATURE_VIRTUAL_CHANNEL, dht.readTemperature(), "temp", "c");
// This function is called at intervals to send humidity sensor data to Cayenne.
CAYENNE_OUT(HUMIDITY_VIRTUAL_CHANNEL)
Cayenne.virtualWrite(HUMIDITY_VIRTUAL_CHANNEL, dht.readHumidity(), "rel_hum", "p");
Cayenne.virtualWrite(VIRTUAL_CHANNEL3, analogRead(SENSOR_PIN3));
Cayenne.virtualWrite(VIRTUAL_CHANNEL4, analogRead(SENSOR_PIN4));
Cayenne.virtualWrite(VIRTUAL_CHANNEL5, analogRead(SENSOR_PIN5));
Cayenne.virtualWrite(VIRTUAL_CHANNEL6, analogRead(SENSOR_PIN6));
and com port monitor:
AT
[1530] ESP is not responding
AT
ATE0
AT+CIPMUX=1
AT+CWMODE?
AT+CWJAP="Nikolskaia33_2GEXT","89859248161"
[8095] Connected to WiFi
[8095] Connecting to mqtt.mydevices.com:1883
AT+CIPSTART=1,"TCP","mqtt.mydevices.com",1883
AT+CIPSEND=1,40
⸮MQIsdp⸮<$7d254820-7256-11e9-beb3AT+CIPSEND=1,40
-736c9e4bf7d0$291ec810-488a-11e8-bf56-dAT+CIPSEND=1,40
2af113f3c1a4f[8973] Connected
AT+CIPSEND=1,40
2b326/things/7d254820-7256-11e9-beb3-736AT+CIPSEND=1,16
c9e4bf7d0/cmd/+[9548] Publish: topic 4, channel 65534, value Arduino Uno, subkey , key
AT+CIPSEND=1,40
1j]v1/291ec810-488a-11e8-bf56-db14f0c2b[19577] Publish: topic 6, channel 65534, value ATmega328P, subkey , key
AT+CIPSEND=1,40
1mav1/291ec810-488a-11e8-bf56-db14f0c2b[29607] Publish: topic 7, channel 65534, value 16000000, subkey , key
AT+CIPSEND=1,40
[34970] Publish: topic 5, channel 65534, value 1.3.0, subkey , key
AT+CIPSEND=1,40
[39987] Publish: topic 8, channel 65534, value ESP8266Shield, subkey , key
[40057] Publish: topic 1, channel 7, value 24.600, subkey c, key temp
AT+CIPSEND=1,40
[45078] Publish: topic 1, channel 8, value 42.500, subkey p, key rel_hum
AT+CIPSEND=1,40
[50096] Publish: topic 1, channel 1, value 0, subkey , key
AT+CIPSEND=1,40
[55112] Publish: topic 1, channel 2, value 0, subkey , key
AT+CIPSEND=1,40
[60128] Publish: topic 1, channel 3, value 161, subkey , key
AT+CIPSEND=1,40
[65144] Publish: topic 1, channel 4, value 296, subkey , key
AT+CIPSEND=1,40
[70160] Publish: topic 1, channel 5, value 360, subkey , key
AT+CIPSEND=1,40
[75176] Publish: topic 1, channel 6, value 363, subkey , key
AT+CIPSEND=1,40
[80193] Connection ok
AT+CIPSEND=1,2
[85239] Publish: topic 1, channel 7, value 24.600, subkey c, key temp
[85241] Publish: topic 1, channel 8, value 42.400, subkey p, key rel_hum
[85246] Publish: topic 1, channel 1, value 0, subkey , key
[85252] Publish: topic 1, channel 2, value 0, subkey , key
[85258] Publish: topic 1, channel 3, value 162, subkey , key
[85263] Publish: topic 1, channel 4, value 219, subkey , key
[85268] Publish: topic 1, channel 5, value 309, subkey , key
[85273] Publish: topic 1, channel 6, value 318, subkey , key
AT+CIPSEND=1,2
AT+CIPCLOSE=1
[95305] Disconnected
[95305] Connecting to mqtt.mydevices.com:1883
AT+CIPSEND=1,40
2af113f3c1a4f[96369] Connected
AT+CIPSEND=1,40
c9e4bf7d0/cmd/+[97074] Publish: topic 4, channel 65534, value Arduino Uno, subkey , key
AT+CIPSEND=1,40
1j]v1/291ec810-488a-11e8-bf56-db14f0c2b[107103] Publish: topic 6, channel 65534, value ATmega328P, subkey , key
AT+CIPSEND=1,40
1mav1/291ec810-488a-11e8-bf56-db14f0c2b[117132] Publish: topic 7, channel 65534, value 16000000, subkey , key
AT+CIPSEND=1,40
[122413] Publish: topic 5, channel 65534, value 1.3.0, subkey , key
AT+CIPSEND=1,40
[127430] Publish: topic 8, channel 65534, value ESP8266Shield, subkey , key
[127470] Publish: topic 1, channel 7, value 24.600, subkey c, key temp
AT+CIPSEND=1,40
[132491] Publish: topic 1, channel 8, value 43.000, subkey p, key rel_hum
AT+CIPSEND=1,40
[137509] Publish: topic 1, channel 1, value 0, subkey , key
AT+CIPSEND=1,40
[142526] Publish: topic 1, channel 2, value 0, subkey , key
AT+CIPSEND=1,40
[147542] Publish: topic 1, channel 3, value 162, subkey , key
AT+CIPSEND=1,40
[152558] Publish: topic 1, channel 4, value 297, subkey , key
AT+CIPSEND=1,40
[157574] Publish: topic 1, channel 5, value 357, subkey , key
AT+CIPSEND=1,40
[162590] Publish: topic 1, channel 6, value 357, subkey , key
AT+CIPSEND=1,40
[167606] Connection ok
AT+CIPSEND=1,2
[172652] Publish: topic 1, channel 7, value 24.600, subkey c, key temp
[172654] Publish: topic 1, channel 8, value 42.800, subkey p, key rel_hum
[172660] Publish: topic 1, channel 1, value 0, subkey , key
[172665] Publish: topic 1, channel 2, value 0, subkey , key
[172670] Publish: topic 1, channel 3, value 161, subkey , key
[172676] Publish: topic 1, channel 4, value 220, subkey , key
[172681] Publish: topic 1, channel 5, value 311, subkey , key
[172687] Publish: topic 1, channel 6, value 311, subkey , key
AT+CIPSEND=1,2
AT+CIPCLOSE=1
[182719] Disconnected
[182719] Connecting to mqtt.mydevices.com:1883
AT+CIPSEND=1,40
2af113f3c1a4f[184016] Connected
AT+CIPSEND=1,40
c9e4bf7d0/cmd/+[184589] Publish: topic 4, channel 65534, value Arduino Uno, subkey , key
AT+CIPSEND=1,40
and I didn’t add any widget, but nothing pops up no Chanels at all. Waiting for your help. Thanks.
