Yes, that is an AT command
ok, give several min
I donât know whats happened, but now it doesnât react on AT command
Remember to to set Both NL & CR in the serial monitor.
Ready
AT
OK
AT+CIOBAUD=9600
OK
This is serial monitor with this code:
//AT+CIOBAUD=9600
#include <SoftwareSerial.h>
SoftwareSerial ESPserial(2, 3);
// RX | TXAT+CIOBAUD=9600
Serial.begin(9600); // communication with the host computer
//while (!Serial) { ; }
// Start the software serial for communication with the ESP8266
ESPserial.begin(9600);
Serial.println("");
Serial.println("Remember to to set Both NL & CR in the serial monitor.");
Serial.println("Ready");
Serial.println("");
// listen for communication from the ESP8266 and then write it to the serial monitor
if ( ESPserial.available() ) { Serial.write( ESPserial.read() ); }
// listen for user input and send it to the ESP8266
if ( Serial.available() ) { ESPserial.write( Serial.read() ); }
Once you have the baud rate rate to 9600 , change it in the code from this post.
Hi. Iâve done, thats what I get in serial monitor:
[1533] ESP is not responding
[6423] Connected to WiFi
[6423] Connecting to mqtt.mydevices.com:1883
[7670] Connected
[8461] Publish: topic 4, channel 65534, value Arduino Uno, subkey , key
[13498] Publish: topic 6, channel 65534, value ATmega328P, subkey , key
[18535] Publish: topic 7, channel 65534, value 16000000, subkey , key
[23570] Publish: topic 5, channel 65534, value 1.3.0, subkey , key
[28602] Publish: topic 8, channel 65534, value ESP8266Shield, subkey , key
[28674] Publish: topic 1, channel 0, value 28674, subkey , key
[38664] Connection ok
[43693] Publish: topic 1, channel 0, value 43693, subkey , key
[48690] Connection ok
[58720] Publish: topic 1, channel 0, value 58720, subkey , key
[64225] Connection ok
that means it is working.
Yep, I understand, but why it doesnât work when I start to use it?)))
what do you mean by that? it is connected and it is publishing data to cayenne.
Now if I start to put the sensors in to the code and make widgets, its working like 5-10 seconds and disconnected, then in 1-2-3 min its connecting again and work for 5-10 seconds and disconnecting again
You know what, yesterday I upload this code:
define CAYENNE_PRINT Serial // Comment this out to disable prints and save space
#include <DHT.h>
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "3";
#define EspSerial Serial
#define SENSOR_PIN1 A0
#define VIRTUAL_CHANNEL1 1
#define SENSOR_PIN2 A1
#define VIRTUAL_CHANNEL2 2
#define DHTPIN 2 // Digital pin connected to the DHT sensor
#define RELEY_VIRTUAL_CHANNEL 9
#define ACTUATOR_PIN 4
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
#define DHTTYPE DHT21 // DHT 21 (AM2301)
#define TEMPERATURE_VIRTUAL_CHANNEL 7
#define HUMIDITY_VIRTUAL_CHANNEL 8
DHT dht(DHTPIN, DHTTYPE); // Initialize DHT sensor.
ESP8266 wifi(&EspSerial);
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
dht.begin();
CAYENNE_IN(RELEY_VIRTUAL_CHANNEL)
if (getValue.asInt() == 0) {
digitalWrite(ACTUATOR_PIN, LOW);
else {
digitalWrite(ACTUATOR_PIN, HIGH);
CAYENNE_OUT(TEMPERATURE_VIRTUAL_CHANNEL)
Cayenne.virtualWrite(TEMPERATURE_VIRTUAL_CHANNEL, dht.readTemperature(), "temp", "c");
// This function is called at intervals to send humidity sensor data to Cayenne.
CAYENNE_OUT(HUMIDITY_VIRTUAL_CHANNEL)
Cayenne.virtualWrite(HUMIDITY_VIRTUAL_CHANNEL, dht.readHumidity(), "rel_hum", "p");
CAYENNE_OUT_DEFAULT()
Cayenne.virtualWrite(VIRTUAL_CHANNEL1, analogRead(SENSOR_PIN1));
Cayenne.virtualWrite(VIRTUAL_CHANNEL2, analogRead(SENSOR_PIN2));
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
to my chaines Arduino Nano and its still working without any disconnection, but my original Italian Arduino uno doesnât
can you share the entire serial monitor output during the connect and disconnect event.
give me some time, cause my nano is in my country house, but Iâam in town now, and I donât have sensors with me, I will try without sensors
hold on, should I leave my rx and tx in 2 and 3 pins, or I need to move it to rx and tx?
you tried the software serial code on the arduino nano or uno? if on uno, try it on nano with rx and tx in 2 and 3.
On uno with 2 and 3:
60972] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[66008] Publish: topic 1, channel 0, value 66008, subkey , key
[71036] Connection ok
[76096] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[76102] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[76179] Publish: topic 1, channel 0, value 76178, subkey , key
[86297] Disconnected
[86297] Connecting to mqtt.mydevices.com:1883
[87605] Connected
[88740] Publish: topic 4, channel 65534, value Arduino Uno, subkey , key
[93778] Publish: topic 6, channel 65534, value ATmega328P, subkey , key
[98816] Publish: topic 7, channel 65534, value 16000000, subkey , key
[103851] Publish: topic 5, channel 65534, value 1.3.0, subkey , key
[108883] Publish: topic 8, channel 65534, value ESP8266Shield, subkey , key
[108931] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[109717] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[110435] Publish: topic 1, channel 0, value 110435, subkey , key
[111142] Connection ok
[121171] Connection ok
[123945] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[124665] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[129705] Publish: topic 1, channel 0, value 129705, subkey , key
[134735] Connection ok
[138953] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[143990] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[149028] Publish: topic 1, channel 0, value 149028, subkey , key
[154057] Connection ok
[159117] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[159124] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[159202] Publish: topic 1, channel 0, value 159201, subkey , key
[169322] Disconnected
[169322] Connecting to mqtt.mydevices.com:1883
[170584] Connected
[171417] Publish: topic 4, channel 65534, value Arduino Uno, subkey , key
[176455] Publish: topic 6, channel 65534, value ATmega328P, subkey , key
[181492] Publish: topic 7, channel 65534, value 16000000, subkey , key
[186527] Publish: topic 5, channel 65534, value 1.3.0, subkey , key
[191559] Publish: topic 8, channel 65534, value ESP8266Shield, subkey , key
[191605] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[192394] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[193105] Publish: topic 1, channel 0, value 193105, subkey , key
[193805] Connection ok
[203834] Connection ok
[206607] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[207318] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[212358] Publish: topic 1, channel 0, value 212358, subkey , key
[217387] Connection ok
[221636] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[226674] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[231711] Publish: topic 1, channel 0, value 231711, subkey , key
[236740] Connection ok
[241799] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[241806] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[241884] Publish: topic 1, channel 0, value 241883, subkey , key
[252005] Disconnected
[252005] Connecting to mqtt.mydevices.com:1883
[253245] Connected
[254093] Publish: topic 4, channel 65534, value Arduino Uno, subkey , key
[259132] Publish: topic 6, channel 65534, value ATmega328P, subkey , key
[264170] Publish: topic 7, channel 65534, value 16000000, subkey , key
[269206] Publish: topic 5, channel 65534, value 1.3.0, subkey , key
[274239] Publish: topic 8, channel 65534, value ESP8266Shield, subkey , key
[274285] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[275290] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[276302] Publish: topic 1, channel 0, value 276302, subkey , key
[277195] Connection ok
[287224] Connection ok
[289305] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[290251] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[295291] Publish: topic 1, channel 0, value 295291, subkey , key
[300320] Connection ok
[304329] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[309366] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[314404] Publish: topic 1, channel 0, value 314404, subkey , key
[319433] Connection ok
[324493] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[324500] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[324578] Publish: topic 1, channel 0, value 324577, subkey , key
[334698] Disconnected
[334698] Connecting to mqtt.mydevices.com:1883
[335913] Connected
[336760] Publish: topic 4, channel 65534, value Arduino Uno, subkey , key
[341799] Publish: topic 6, channel 65534, value ATmega328P, subkey , key
[346838] Publish: topic 7, channel 65534, value 16000000, subkey , key
[351873] Publish: topic 5, channel 65534, value 1.3.0, subkey , key
[356905] Publish: topic 8, channel 65534, value ESP8266Shield, subkey , key
[356953] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[357662] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[358341] Publish: topic 1, channel 0, value 358340, subkey , key
[359005] Connection ok
[369034] Connection ok
[371959] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[372933] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[377972] Publish: topic 1, channel 0, value 377972, subkey , key
[383001] Connection ok
[386979] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[392017] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[397056] Publish: topic 1, channel 0, value 397056, subkey , key
[402085] Connection ok
[407145] Publish: topic 1, channel 7, value NAN, subkey c, key temp
[407152] Publish: topic 1, channel 8, value NAN, subkey p, key rel_hum
[407230] Publish: topic 1, channel 0, value 407229, subkey , key
[417350] Disconnected
[417350] Connecting to mqtt.mydevices.com:1883
[419010] Connected
[420046] Publish: topic 4, channel 65534, value Arduino Uno, subkey , key
[425085] Publish: topic 6, channel 65534, value ATmega328P, subkey , key
[430123] Publish: topic 7, channel 65534, value 16000000, subkey , key
with this code:
#include <DHT.h>
#define VIRTUAL_CHANNEL 1
char ssid[] = "";
char clientID[] = "";
//#define EspSerial Serial
#define DHTPIN 5 // Digital pin connected to the DHT sensor
SoftwareSerial EspSerial(2,3);
delay(10);
EspSerial.begin(9600);
delay(10);
but it doesnât show the temperature
for temperature issue, you are missing dht.begin();
in the void setup.
the disconnect issue maybe due to various reason, one maybe a faulty uno, other maybe power supply issue. Did you use a voltage divide between uno and esp?
my mistake
now I use this code:
Steps:
#include <DHT.h>
char ssid[] = "";
char username[] = "291";
char clientID[] = "9f\";
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
delay(10);
delay(10);
dht.begin();
else {
and every thing is working now, without any disconnection for already 10 minutes.
for my esp I use this thing:
May be different router settings?
