TSL2561 Failed to add the sensor (Device command failed)
Hello all !
I want add luminosity sensor but when i want save it i’ve message which say :
SOmebody can help me ?
can you PM me your email_id.
I am also getting the same problem
can you try now if you get the issue while adding the TSL2561 and let me know.
Hi Shramik, I encountered the same problem and error message when I was adding a PIR motion sensor to channel 18. I’ve PMed you my email id.
you can now add new data to the dashboard by sending an uplink to a particular channel.
Example:-
Cayenne.virtualWrite(3, PIR_DATA, motion, d)
