Raspberry Pi 4 8GB -
Web -
Please describe the bug / issue as detailed as possible.
I tried to add my Motion Sensor which is HC-SR501 and connect it exactly like the official guide on Cayenne Docs, but everytime i do that i get this error Failed to add the sensor (Device command failed), i tried to use another GPIO pin and same problem occurs, also everytime i tried to enable I2C from myDevices Web then my Raspberry Pi will not show online on the website even though im writing this from my Raspberry Pi.
when executing the command: service myDevice status i get
myDevices.service - myDevices service
Loaded: loaded (/etc/systemd/system/myDevices.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2020-09-30 11:36:17 +03; 13min ago
Process: 1658 ExecStartPre=/bin/mkdir -p /var/run/myDevices (code=exited, status=0/SUCCESS)
Process: 1659 ExecStartPre=/bin/chown cayenne:cayenne /var/run/myDevices/ (code=exited, status=0/SUCCESS)
Process: 1660 ExecStartPre=/bin/mkdir -p /var/log/myDevices (code=exited, status=0/SUCCESS)
Process: 1661 ExecStartPre=/bin/chown -R cayenne:cayenne /var/log/myDevices/ (code=exited, status=0/SUCCESS)
Process: 1662 ExecStartPre=/bin/chown cayenne:cayenne /etc/myDevices (code=exited, status=0/SUCCESS)
Process: 1663 ExecStartPre=/bin/chown cayenne:cayenne /etc/myDevices/AppSettings.ini (code=exited, status=0/SUCCESS)
Process: 1664 ExecStartPre=/bin/chown cayenne:cayenne /etc/myDevices/agent.db* (code=exited, status=1/FAILURE)
Process: 1665 ExecStartPre=/bin/chown cayenne:cayenne /etc/myDevices/devices.json (code=exited, status=0/SUCCESS)
Process: 1666 ExecStartPre=/bin/mkdir -p /etc/myDevices/plugins (code=exited, status=0/SUCCESS)
Main PID: 1667 (python3)
Tasks: 0 (limit: 4915)
CGroup: /system.slice/myDevices.service
‣ 1667 /usr/bin/python3 -m myDevices -P /var/run/myDevices/cayenne.pid
Sep 30 11:36:17 raspberrypi systemd[1]: Starting myDevices service…
Sep 30 11:36:17 raspberrypi systemd[1]: Started myDevices service.
Sep 30 11:36:17 raspberrypi systemd[1667]: pam_unix(login:session): session opened for user cayenne by (uid=0)
I tried to format the SD card then made another image but same problem occurs when i add motion sensor
