I can get values of button on serial port as i triggers it but i can’t get the LED to light up
Below is my code:
#define vp1 1
#define vp2 2
char ssid = “xxx”;
char wifiPassword = “xxx”;
char username = “xxx”;
char password = “xxx”;
char clientID = “xxx”;
unsigned long lastMillis = 0;
pinMode(D2, OUTPUT);
Serial.begin(115200);
if (millis() - lastMillis > 3000)
lastMillis = millis();
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN(vp1)
if (currentValue == 1) {
digitalWrite(D2, HIGH);
Serial.println(“a”);
else {
digitalWrite(D2, LOW);
CAYENNE_IN(2)
digitalWrite(D0, HIGH);
Serial.println(“B”);
else {
digitalWrite(D0, LOW);
This is what i saw from Serial Port
[2048] Connected to WiFi
[2048] IP: 192.168.43.232
[2048] Connecting to mqtt.mydevices.com:1883
[2934] Connected
[7420] Channel 65534, value 1
[10640] Channel 65534, value 0
As for the setup, i just link a wire from D2 to positive side of LED bulb while the other goes to ground
Pls help, Thanks
