Hi, I’m a newbie working on a Voice assistant to MQTT project. I’ve connected an RGB LED strip to an active low relay module. In the code below, The communication between MQTT and Arduino’s Serial is working perfectly except my function OffRelay(). Am I doing something work here?
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <WiFiClientSecure.h>
// Connect to the WiFi
const char* ssid = "";
const char* password = "";
const char* mqtt_server = "broker.mqttdashboard.com";
const char* mqtt_user = "";
const char* mqtt_pswd = "";
WiFiClient espClient;
PubSubClient client(espClient);
//Pins are connected to relays
const int RED_PIN = 12; //D6: Red Pin
const int GREEN_PIN = 14; //D5: Green Pin
const int BLUE_PIN = 13; //D7: Blue Pin
unsigned long currentTime;
unsigned long startTime;
unsigned long period = 1;
int countR;
int countG;
int countB;
bool power=false;
// The function below connects your NodeMCU to the wireless network
void setup_wifi(){
Serial.begin(38400);
Serial.println();
Serial.print("connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
delay(2000);
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Payload selected [");
Serial.print(topic);
Serial.print("]=> ");
for (int i = 0; i < length; i++) {
char receivedChar = (char)payload[i];
if(receivedChar=='0'){
Serial.print("Rainbow On");
power=true;
OnRelays();
if(receivedChar=='1'){
Serial.print("Rainbow Off");
power=false;
OffRelays();
Serial.println();
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.println("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("Reception"),mqtt_user,mqtt_pswd) { // "explicit name for each client"
Serial.print("Reception is connected to ");
Serial.println(mqtt_user);
// ... and subscribe to topic
client.subscribe("RGB/Output");//Topic subscribed to
} else {
Serial.print("Failed to connect to MQTT...");
Serial.println();
Serial.println("Attempting to connect again in 3 seconds.");
// Wait seconds before retrying
delay(3000);
void OnRelays(){
digitalWrite(RED_PIN, LOW);
digitalWrite(GREEN_PIN, LOW);
digitalWrite(BLUE_PIN, LOW);
void OffRelays(){
digitalWrite(RED_PIN, HIGH);
digitalWrite(GREEN_PIN, HIGH);
digitalWrite(BLUE_PIN, HIGH);
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
pinMode(RED_PIN, OUTPUT);
pinMode(GREEN_PIN, OUTPUT);
pinMode(BLUE_PIN, OUTPUT);
if (!client.connected()) {
reconnect();
client.loop();
if(power==true)
RainbowEffect();
else{
countR=0;
countG=0;
countB=0;
SetColours();
void RainbowEffect()
currentTime = millis();
if (currentTime - startTime >= period)
countR++;
if (countR > 255)
countR = 0;
countG++;
if (countG > 255)
countG = 0;
countB++;
if (countB > 255)
countB = 0;
SetColours();
startTime = currentTime;
void SetColours(){
analogWrite(RED_PIN,countR);
analogWrite(GREEN_PIN,countG);
analogWrite(BLUE_PIN,countB);
