Just received an email today about the intent to decomission the REST API integration with Cayenne on March 31/2020
If this is to be decommissioned, what is the best option for me to query temperature settings and remotely set relays on/off if I cannot do it through the REST API?
Robert
I would seem to me that you could have a middle-ground between the teenager who will fiddle with his arduino for a few weeks (and get the free service), and the professional setting up monitoring on a chain of restaurants.
I’m guessing the REST-API users are 99% just fetching data to use or present in a more useful way than looking at the couple of graphs on the website or downloading a csv. And then once in a while sending a command to control something. All the REST-API functions for adding/listing rules, devices, users, … and all the fancy functionality of the OAuth system would get little use. That is for the middle-user, not the chain-of-restaurants user.
So perhaps you could charge a fee for just that – rather than pursue the corporate contract for a full system.
You can get nearly free databases from Amazon, Microsoft, Google or just set it all up on a $20 Raspberry PI and skip the internet entirely.
I don’t think I fit into the “chain of restaurants” model.
IoT in a Box - REST API · Apiary .
https://iotinabox.zendesk.com/hc/en-us/articles/360022622174-Query-your-White-Label-data-data-using-the-REST-API
Hi @retovell ,
You may still gather such information using the following API under this host: cayenne.mydevices.com . The authentication to obtain JWT tokens are the same as previous examples.
History/Telemetry API:
Get latest history for a sensor:
GET /cayenne/api/cayenneapi/history/{THING_ID}/{SENSOR_ID}?type=latest
curl --request GET \
--url 'https://cayenne.mydevices.com/cayenne/api/cayenneapi/history/THING_ID/SENSOR_ID?type=latest' \
--header 'authorization: Bearer JWT_TOKEN'
Query custom date range:
GET /cayenne/api/cayenneapi/history/{THING_ID}/{SENSOR_ID}?endDate={}&startDate={}&type=custom
Query params: endDate & startDate are in UTC milliseconds.
Looking into the command API for you and will provide updates.
Thanks for your comments @jameszahary , but the IoT in a Box is not just for restaurant use cases, its for a broader industry. Also, the IoT in a box is not compatible with Cayenne.
We will be bringing a lot of cool features from Cayenne to IoT in a Box.
Hi, I used REST API with ESP8266. Can you help me, how i need set the authentication now. In my code I have those credentials
// cayenne server names
const char cayaddr = “mqtt.mydevices.com ”;
const char cayserver = “platform.mydevices.com ”;
const char cayauthserver = “accounts.mydevices.com ”;
those endpoints are not supported. you will have to use this.
Thansk for your answer. But I am amateur and I would like to asked you about help. We have solved this problem in the past ( Read data from Dashboard every 10 minutes ), could you refer me to some example project?
I read it, but I need help with my code. Here is an important part of my example:
// your wifi name and password
const char ssid[] =
const char wifipassword[] =
// cayenne username and password for MQTT
const char cayusername[] =
const char caypassword[] =
// cayenne device name and sensor name
const char cayclientID[] =
const char caycycles[] =
const char cayaddr[] = "mqtt.mydevices.com";
const char cayserver[] = "platform.mydevices.com";
const char cayauthserver[] = "accounts.mydevices.com";
// cayenne username and password to access REST API
const char client_id[] =
const char client_secret[] =
const char username[] =
const char password[] =
// the access token JWT for actual access
char access_token[1200] = "";
char refresh_token[700] = "";
// get currect value of device and sensor, returned in global variables v, ts, unit, device_type
int rest_query_cayenne(const char caydev[], const char caysen[]);
//int rest_query_cayenne1(const char caydev[], const char caysen1[]);
// get a day of history of the device and sensor -- just print it out
//int rest_query_cayenne_day(const char caydev[], const char caysen[]);
do_access_token();
Cayenn();
delay(60000);
void Cayenn() {
if ( rest_query_cayenne( cayclientID, caycycles) == 1) {
temp = v;
Serial.println("Temperature");
Serial.print(temp, 1);
Serial.println(" °C");
} else {
Serial.println("Couldn't access REST API");
void do_access_token() {
WiFiClientSecure cayclient;
HTTPClient cayhttp;
cayclient.setInsecure();
if (cayclient.connect(cayauthserver, 443)) {
if (cayhttp.begin(cayclient, "https://accounts.mydevices.com/auth/realms/cayenne/protocol/openid-connect/token")) {
cayhttp.addHeader("Content-Type", "application/x-www-form-urlencoded");
cayhttp.addHeader("cache-control", "no-cache");
String body = "grant_type=password&client_id=" + String(client_id) + "&client_secret=" + String(client_secret) + "&username=" + String(username) + "&password=" + String(password) ;
int httpCode = cayhttp.POST(body);
if (httpCode > 0) {
// HTTP header has been send and Server response header has been handled
//Serial.printf("[HTTPS] POST... code: %d\n", httpCode);
if (httpCode == HTTP_CODE_OK || httpCode == HTTP_CODE_MOVED_PERMANENTLY) {
String payload = cayhttp.getString();
//Serial.println(payload);
DynamicJsonBuffer jsonBuffer(2000);
JsonObject& root = jsonBuffer.parseObject(payload);
if (!root.success()) {
Serial.println("parseObject failed");
return ;
} else {
String at = root["access_token"];
String rt = root["refresh_token"];
Serial.println("access token =" + at);
//Serial.println("");
//Serial.println("refresh token =" + rt);
at.toCharArray(access_token, 1200);
rt.toCharArray(refresh_token, 700);
} else {
Serial.printf("[HTTPS] POST... failed, error: %s\n", cayhttp.errorToString(httpCode).c_str());
cayhttp.end();
} else {
Serial.printf("[HTTPS] Unable to connect\n");
} else {
Serial.println("Cay Auth Server failed to connect");
cayclient.stop();
int rest_query_cayenne(const char caydev[], const char caysen[]) {
HTTPClient cayhttp;
int ret = 0;
if (!cayclient.connect(cayserver, 443)) {
Serial.println("Cayserver failed to connect");
} else {
String get = "https://platform.mydevices.com/v1.1/telemetry/" + String(caydev) + "/sensors/" + String(caysen) + "/summaries?endDateLatest=true&type=latest";
//Serial.println(get);
if (cayhttp.begin(cayclient, get)) {
cayhttp.addHeader("Authorization" , "Bearer " + String(access_token));
int httpCode = cayhttp.GET();
if (httpCode > 0) {
//Serial.printf("[HTTPS] GET... code: %d\n", httpCode);
int payload_length = payload.length();
//Serial.print("Payload length is "); Serial.println(payload_length);
// [{"v":"1526700604","ts":"2018-05-19T03:30:05.283Z","unit":"seconds","device_type":"analog"}]
DynamicJsonBuffer arrayBuffer(100);
DynamicJsonBuffer jsonBuffer(100);
JsonArray& array = arrayBuffer.parseArray(payload, 2);
int size = array.size();
//Serial.print("Array Size is "); Serial.println(size);
String onejson = array[0];
JsonObject& root = jsonBuffer.parseObject(onejson);
} else {
double xv = root["v"];
String xts = root["ts"];
String xdevice_type = root["device_type"];
String xunit = root["unit"];
v = xv;
ts = xts;
device_type = xdevice_type;
unit = xunit;
return 1;
jsonBuffer.clear();
} else {
Serial.println(httpCode);
cayhttp.end();
cayclient.stop();
int rest_query_cayenne_day(const char caydev[], const char caysen[]) {
// results v, ts, device, unit
HTTPClient cayhttp;
int ret = 0;
} else {
String get = "https://platform.mydevices.com/v1.1/telemetry/" + String(caydev) + "/sensors/" + String(caysen) + "/summaries?endDateLatest=true&type=day";
if (httpCode > 0) {
// [{"v":"1526700604","ts":"2018-05-19T03:30:05.283Z"},{"v":"1526700604","ts":"2018-05-19T03:30:05.283Z"}]
DynamicJsonBuffer arrayBuffer(500);
for (int ii = 0; ii < size; ii++ ) {
String onejson = array[ii];
//Serial.print(ii); Serial.print(" >"); Serial.print(onejson); Serial.println("<");
} else {
Serial.print("index "); Serial.print(ii);
Serial.print("\t v "); Serial.print(xv);
Serial.print("\t ts "); Serial.print(xts);
Serial.println("");
v = xv;
ts = xts;
} else {
cayhttp.end();
cayclient.stop();
where did you get this code from?
I found it on the Internet in the past and modified it for my use, but I do not remember the source
most of the code will be same to get the JWT token. you need to modify this:
with:
Is It right?
String get = “Log in to Cayenne ”;
cayhttp.addHeader(“Authorization” , "Bearer JWT_TOKEN " + String(access_token));
hrubosz:
THING_ID/SENSOR_ID
you need to pass the value here
String get = “https://cayenne.mydevices.com/cayenne/api/cayenneapi/history/ " + String(THING_ID )+ String(SENSOR_ID) + “?type=latest”
I don’t know where I’m making a mistake, but it doesn’t seem to work
did you make the changes i mentioned above. can you share the code.
Serial.println(“Cayserver failed to connect”);
} else {
String get = “https://cayenne.mydevices.com/cayenne/api/cayenneapi/history/ ” + String(caydev) + String(caysen) + “?type=latest”;
I apologize for stupid questions, but I’m a beginner. I read temperature data (ESP8266+DS18B20) and send to dashboard. With other ESP8266 I need read temperature from dashboard and display on OLED display ones per 10 minutes. During 10 minutes is ESP disconnected from dashboard and is reconnected every 10 minutes.
It has moved a bit, but it still does not work, the serial monitor displays:
Payload length is 2
Array Size is 0
parseObject failed
Couldn’t access REST API
