#define CAYENNE_PRINT Serial #define CAYENNE_DEBUG
char username = “–”;
char password = “verystrong”;
char clientID = “hackersnotwelcome”;
#define SENSOR_PIN 16 // Do not use digital pins 0 or 1 since those conflict with the use of Serial. #define VIRTUAL_CHANNEL 9
int previousState = -1;
int currentState = -1;
void checkSensor()
if (currentMillis - previousMillis >= 1000) {
currentState = digitalRead(SENSOR_PIN);
Cayenne.virtualWrite(VIRTUAL_CHANNEL, currentState, “digital_sensor”, “d”);
previousState = currentState;
Looks fine to me. That garbage is from the ESP booting. If you set the baud to 115200 you should see some actual info. No clue why it’s not printing debug messages though. Does it show up as online on the dashboard?
The temporary widget appears in the cayenne dashboard, and it gives out 0/1 values, but not correct ones. When I put the widget with a icon, it literally “blinks”, but it should be 1 when the motion sensor detects movement and 0 when it does not detect movement.
The motion sensor is working, because when I connect it directly to raspberry GPIOs instead of the ESP8266, it works perfectly in the dashboard.
Steps:
1. If you have not already installed the ESP8266 Board Package install it using the instructions here: https://github.com/esp8266/Arduino#installing-with-boards-manager.
2. Select your ESP8266 board from the Tools menu.
char ssid[] = "ssid";
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
The problem was that I did not connect the ground pin of my ESP8266 to the ground pin of the raspberry pi (that was feeding/powering the motion sensor module).
I had to shunt the ground pin of the raspberry pi with the ground pin of the ESP8266, now I’m receiving correct data on the cayenne dashboard and correspondent widget.
