My desktop has changed. All widgets are now a different style. Seems to be totally random. Widget that were gauges are now charts, that sort of thing. Any update if this will stay this way?
Thanks,
John
Same - lost all my desktops - values all zeros - was fine earlier???
We are doing a website update. Your widgets will be back to normal in the next hour.
The REST API system also not working. I can get authorized, but cannot access sensors. And all the projects are gone.
I assume it is the same issue as above.
We need to finish a migration for projects and we will look into the REST API.
Hello @acedeno. may i know when the REST API would get back to normal (roughly), please? as we are using this API too for work.
now we can get the access_token, but when we use it to generate thing id or command actuator from api, it returns ![]()
{âmessageâ:âNo credentials found for given âissââ}
thanks for the effort.
cannot give an ETA on this. The team is working on it right now.
@jameszahary @kingccf can you share the code you are using, so we can try and reproduce at our end what is the issue.
Download, enable editing and macros, enter user/pass, and âŚ
Step 1 - get credentials - seems to work
Step 2 - get_things() - returns this http below - I do not recall this âissâ comment from the debugging
403
{"message":"No credentials found for given âissâ"}
It seems to deliver a bad access_token.
If you paste the access token into
⌠it prints out my email and user numbers, but ends with âInvalid signatureâ.
Hi.
i use nodejs to send HTTP POST. but you can send HTTP POST directly ( i use âPostmanâ) to reproduce this issue:
https://platform.mydevices.com/v1.1/things/types
header : Authorization : Bearer âaccess_tokenâ
( please change "access_token)
body:
{ânameâ: âMy Gatewayâ,
âdescriptionâ: âA sample gatewayâ,
âversionâ: âv1.0â,
âmanufacturerâ: âExample Inc.â,
âcodecâ: âsome.codec.nameâ,
âparent_constraintâ: âNOT_ALLOWEDâ,
âchild_constraintâ: âALLOWEDâ,
âcategoryâ: âmoduleâ,
âsubcategoryâ: âsampleâ,
âtransport_protocolâ: âsomeprotocolâ}
hope this can be solved soon. as we have lots of products using this project, and our customers are complaining now!
thanks for the effort !
thanks @jameszahary @kingccf we will look into it.
Hi, I have a feeling that I might be having this issue too, Iâm getting a 500 internal server error when accessing the values of my sensors via postman, I was able to get a token but wasnât able to fetch the data using that token, it only gives a 500 internal server error message
@deltasierra23 we are looking into this issue.
I also have this response to https://platform.mydevices.com/v1.1/things GET request :
@BQ_SNIR team is looking into this issue. will let you know once fixed.
