Hi, which widget could i use for my adxl345.
It is working on the Arduino Plotter but I dont find the right widget.
You’d need to build up the [x,y,z] string
Cayenne.virtualWrite(12, [x,y,z], "accel", "g");
you mean in this position? Which Widget should i use?
CAYENNE_OUT(1)
//Cayenne.virtualWrite(1, millis());
Cayenne.virtualWrite(12, [x,y,z], “accel”, “g”);
CAYENNE_OUT12)
it will auto create the widget.
do you have the complete code? Because now with this change I get:
xwas not declared in this scope
Here my code:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
#include <CayenneMQTTESP32.h>
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "----";
char password[] = "";
char clientID[] = "----";
unsigned long lastMillis = 0;
/* Assign a unique ID to this sensor at the same time */
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(12345);
void displaySensorDetails(void)
sensor_t sensor;
accel.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" m/s^2");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" m/s^2");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" m/s^2");
Serial.println("");
delay(500);
void displayDataRate(void)
Serial.print ("Data Rate: ");
switch(accel.getDataRate())
case ADXL345_DATARATE_3200_HZ:
Serial.print ("3200 ");
break;
case ADXL345_DATARATE_1600_HZ:
Serial.print ("1600 ");
break;
case ADXL345_DATARATE_800_HZ:
Serial.print ("800 ");
break;
case ADXL345_DATARATE_400_HZ:
Serial.print ("400 ");
break;
case ADXL345_DATARATE_200_HZ:
Serial.print ("200 ");
break;
case ADXL345_DATARATE_100_HZ:
Serial.print ("100 ");
break;
case ADXL345_DATARATE_50_HZ:
Serial.print ("50 ");
break;
case ADXL345_DATARATE_25_HZ:
Serial.print ("25 ");
break;
case ADXL345_DATARATE_12_5_HZ:
Serial.print ("12.5 ");
break;
case ADXL345_DATARATE_6_25HZ:
Serial.print ("6.25 ");
break;
case ADXL345_DATARATE_3_13_HZ:
Serial.print ("3.13 ");
break;
case ADXL345_DATARATE_1_56_HZ:
Serial.print ("1.56 ");
break;
case ADXL345_DATARATE_0_78_HZ:
Serial.print ("0.78 ");
break;
case ADXL345_DATARATE_0_39_HZ:
Serial.print ("0.39 ");
break;
case ADXL345_DATARATE_0_20_HZ:
Serial.print ("0.20 ");
break;
case ADXL345_DATARATE_0_10_HZ:
Serial.print ("0.10 ");
break;
default:
Serial.print ("???? ");
break;
Serial.println(" Hz");
void displayRange(void)
Serial.print ("Range: +/- ");
switch(accel.getRange())
case ADXL345_RANGE_16_G:
Serial.print ("16 ");
break;
case ADXL345_RANGE_8_G:
Serial.print ("8 ");
break;
case ADXL345_RANGE_4_G:
Serial.print ("4 ");
break;
case ADXL345_RANGE_2_G:
Serial.print ("2 ");
break;
default:
Serial.print ("?? ");
break;
Serial.println(" g");
void setup(void) {
#ifndef ESP32
while (!Serial); // for Leonardo/Micro/Zero
#endif
Serial.begin(115200);
Serial.println("Accelerometer Test"); Serial.println("");
/* Initialise the sensor */
if(!accel.begin())
/* There was a problem detecting the ADXL345 ... check your connections */
Serial.println("Ooops, no ADXL345 detected ... Check your wiring!");
while(1);
/* Set the range to whatever is appropriate for your project */
accel.setRange(ADXL345_RANGE_16_G);
// displaySetRange(ADXL345_RANGE_8_G);
// displaySetRange(ADXL345_RANGE_4_G);
// displaySetRange(ADXL345_RANGE_2_G);
/* Display some basic information on this sensor */
displaySensorDetails();
/* Display additional settings (outside the scope of sensor_t) */
displayDataRate();
displayRange();
Serial.println("");
void loop(void) {
if (millis() - lastMillis > 100) {
lastMillis = millis();
/* Get a new sensor event */
sensors_event_t event;
accel.getEvent(&event);
/* Display the results (acceleration is measured in m/s^2) */
//Serial.print("X: "); Serial.print(event.acceleration.x); Serial.print(" ");
//Serial.print("Y: "); Serial.print(event.acceleration.y); Serial.print(" ");
//Serial.print("Z: "); Serial.print(event.acceleration.z); Serial.print(" ");Serial.println("m/s^2 ");
//delay(10);
//For telemetry viewer uncomment/comment this
Serial.print(", ");
Serial.print(", ");
Serial.println("");
CAYENNE_OUT(1)
//Cayenne.virtualWrite(12, [x,y,z], "accel", "g");
CAYENNE_IN(1)
Store the acceleration value in the variable x, y, z and create the sting.
float x;
float y;
float z;
buffer[0] = '[';
size_t offset = 1;
dtostrf(x, 1, 3, &buffer[offset]);
offset += strlen(&buffer[offset]);
buffer[offset++] = ',';
dtostrf(y, 1, 3, &buffer[offset]);
dtostrf(z, 1, 3, &buffer[offset]);
buffer[offset++] = ']';
buffer[offset] = 0;
Serial.println(buffer);
Cayenne.virtualWrite(12, buffer, “accel”, “g”);
Hi, I get some complex with your code.
How could I link this 3 codes in one function? See the picture attached, there are the 3 values in the Dashboard but i need in one graph
Cayenne.virtualWrite(1, event.acceleration.x);
Cayenne.virtualWrite(2, event.acceleration.y);
Cayenne.virtualWrite(3, event.acceleration.z);
the above code which i gave does the thing. it creates a single widget with all three values.
This is the last part of the code with your support but i become some error codes. Sure i have to delete some codes but i´m not sure
//Cayenne.virtualWrite(1, event.acceleration.x);
//Cayenne.virtualWrite(2, event.acceleration.y);
//Cayenne.virtualWrite(3, event.acceleration.z);
CAYENNE_OUT(12)
buffer[0] = ‘[’;
size_t offset = 1;
buffer[offset++] = ‘,’;
buffer[offset++] = ‘]’;
buffer[offset] = 0;
CAYENNE_IN(12)
you can delete the entire CAYENNE_IN(12) function
Hi, i have delete the entire CAYENNE_IN(12) function as you can see in the picture above without result. I get the fault stray \342 in program
delete the (double quotes)" from "accel" and "g" and retype them.
