Dear friends: I’m working in my project, in which I need to work with a static IP in a wifi connection.
I don’t know how to do this, because when tried to configure Cayenne.begin as it would be done with ManualConnection (for ethernet) example but didn’t work.
error: no matching function for call to ‘CayenneMQTTWiFiClient::begin(char [37], char [41], char [37], char [12], char [12], IPAddress&, IPAddress&, IPAddress&, IPAddress&, byte [6])’
when tried to do
Cayenne.begin(username, password, clientID, ssid, wifiPassword, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac));
Is there any way to work with fixed IPs and wifi connection with cayenne?
Many thanks for your help.
Best regards
Daniel
try this code:-
#define CAYENNE_DEBUG
#include <ESP8266WiFi.h>
IPAddress ip(192, 168, 1, xxx);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
IPAddress DNS(192, 168, 1, 1);
const char* ssid = "xxxxxx";
const char* wifipassword = "xxxxx";
char username[] = "xxxxx";
char password[] = "xxxxx";
char clientID[] = "xxxx";
Serial.begin(115200);
WiFi.config(ip, gateway, subnet, DNS);
delay(100);
//WiFi.mode(WIFI_STA);
WiFi.begin(ssid, wifipassword);
Serial.print("Connecting");
Serial.print(".");
delay(200);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println();
Serial.println("Fail connecting");
delay(5000);
ESP.restart();
Serial.print(" OK ");
Serial.print("Module IP: ");
Serial.println(WiFi.localIP());
thank you!
best regards
DL
