Hi everyone ,please help me for this code
#include <CayenneMQTTWiFi101.h>
char ssid[] = "Majed-4G";
char wifiPassword[] = "0570909101";
char username[] = "676916e0-4cfd-11ec-ad90-75ec5e25c7a4";
char password[] = "857c9860e1ce4e06b3f888c6c00d3b30b4a43ffe";
char clientID[] = "7235fb60-4cfd-11ec-ad90-75ec5e25c7a4";
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
and I have an error when I uploaded it :
Arduino: 1.8.16 (Windows Store 1.8.51.0) (Windows 10), Board: “Arduino Uno”
Sketch uses 35652 bytes (110%) of program storage space. Maximum is 32256 bytes.
text section exceeds available space in boardGlobal variables use 1813 bytes (88%) of dynamic memory, leaving 235 bytes for local variables. Maximum is 2048 bytes.
Sketch too big; see https://support.arduino.cc/hc/en-us/articles/360013825179 for tips on reducing it.
Error compiling for board Arduino Uno.
Invalid library found in C:\Users\USER\Documents\Arduino\libraries\libraries: no headers files (.h) found in C:\Users\USER\Documents\Arduino\libraries\libraries
