Agent 2.0 upgrade
Hello, sorry ahead of time for the dumb question. How do I upgrade my RaspberryPis to the Pi agent 2.0?
on the dashboard go to : add new > device/widget > raspberry pi > and type the command in the ssh terminal.
Ok, is it best to start over with a new SD card image or can you use one that’s already connected to Cayenne?
it is recommended to start on new sd-card.
After doing this i still get the old agent.
Made a fresh stretch light sdcard and added it as a new device and it still ends up with the old agent any ideas?
what do you mean with old agent?
When i log on to the cayenne website after newly adding my pi, i still get the popup that its using the legacy version and when i check it on the webpage it still sais its using Agent Version
1.0.0.20838
And not even run apt-get update/upgrade before Cayenne install, because then it will crash with the newer Python version.
Hello, is the DS18B20 still supported automatically with the 2.0 agent?
yes it should be. have a look at this https://mydevices.com/cayenne/docs/supported-hardware/#supported-hardware-sensors-temperature-ds18b20-arduino-tutorial
Ok, haven’t been able to get it to work. Is the new RaspberryPi 3 B+ supported?
yes. what is problem you are facing.
Just trying to add the ds18b20 but it doesn’t come up after connecting to the GPIO and booting.
#14
hold on, there seems to be some bug with agent 2.0. will notify once it is solved.
