Bug Filed on 04-06-2016: Getting email notifications every minute, can't stop them!
1. What OS? (Wheezy or Jessie) Jessie
2. What class/size SD card? (ex. class 10 16gb) 16gb
3. What Model Pi? (A+, A, B+, B, Pi2) Pi2
I have a Raspberry Pi 2 running Jessie . I had installed cayenne to access it remotely using my iPhone. I had also setup a trigger to send me an email if the system was offline. I have since uninstalled cayenne myDevices and deleted the trigger but I am now receiving an email every minute stating:
ā€œmyDevices is running.
webiopi is running.ā€
the subject is ā€œCron root@raspberrypi /etc/myDevices/crontab.shā€
How can I stop these email from coming and flooding my inbox?
I don’t have a pi with Cayenne on it right here but you can try ā€œcrontab -eā€ to see if you have anything in crontab. Just wipe out anything Cayenne related if there’s anything in there.
Thanks for the tip. I had already tried that but nothing in there :slight_frown:.
Yikes, okay so here’s what you should be able to do to resolve issue immediately:
sudo rm -rf /etc/myDevices && service myDevices stop
You should also remove the Pi from your account since you deleted Cayenne installation from the Pi.
  • click on the edit icon next to your Pi name in left-side device list.
Curious, how did you uninstall Cayenne?
To ā€œUninstallā€ i used the option on cayenne.mydevices.com. I don’t remember the exact wording but when you select the properties for a device it says something like ā€œremove from device, this option can not be undoneā€.
running the above commands changed the email, now the email says:
ā€œ/bin/sh: 1: \etc\myDevices\crontab.shā€ not found"
so it seems to have cleaned up the files but is still generating the emails.
I checked with services --status-all and the myDevices service is no longer listed.
I have changed to configuration to the /etc/ssmtp/ssmtp.conf by comenting out the ā€˜mailhub’ as a temporary fix so that it stops sending the emails, but I need it to stop trying to send them. :grin:
Hmm okay.
Did you actually delete the trigger from your trigger setup? Or did you assume that remove the device also removed the associated triggers?
I removed the trigger as well, currently no triggers in my account.
I PM’d you for your account info. If it’s okay with you, I’ll pass your login credentials to the team so we can take a look.
Yes, already sent.
Thanks.
@rkoutnik Can you turn off your pi and see if the notifications are still received?
No, if the pi is off the emails do not come. I did find the problem though. I had checked with crontab -e and made sure there was nothing there related to myDevices or the issue and there was not. Today I found out that crontab is user specific. So I ran sudo crontab -e and found * / * * * * * /etc/myDevices/crontab.sh
I removed the line and saved the setting, re-ediable the email mailhub and I am no longer getting the alerts.
Thanks for all the help.
You are right, oversight on my part. Should have told you to use sudo.
You had the right idea though, thanks.
Hi @rkoutnik,
Just wanted to confirm, you are no longer receiving the emails right?
Yes, the issue was resolved. It seem the uninstall did not remove the task that it had created in the root’s crontab. So when I checked with crontab -e it was not shown, but checking with sudo crontab -e showed the task and I was able to remove it.
Phwew.
We are implementing an uninstall button on the dashboard, so this shouldn’t happen again. Thanks for working with us!
I have an almost identical problem, except I started getting an email every minute after I first installed Cayenne (instead of after uninstall). Even though this bug is set as ā€œresolved,ā€ the subject is exactly the issue I’m having. If I should create a new bug/question thread, I’m happy to do so.
The email subject is: ā€œCron root@raspberrypi /etc/myDevices/crontab.shā€
and the content of each email is:
webiopi is running.
I restarted my raspberry, no change. In order to stop the emails (other than a possible New Year’s gift), I have changed the crontab from:
          • /etc/myDevices/crontab.sh
            to:
    • 1 1 * /etc/myDevices/crontab.sh
The emails have stopped, but I’m sure that Cayenne must need/expect the crontab.sh to run every minute. Because I’m new to Cayenne, I don’t know what might not be working properly now. I’ll leave it this way until I get some feedback about what I should be doing next.
As a semi-newbie, I’m not sure exactly how to find out what I’m running. The Cayenne web page info says ā€œOS: raspbian 7 (debian) Hardware: Model Bā€ but ssh login message says ā€œLinux raspberrypi 4.1.13+ #826 PREEMPT Fri Nov 13 20:13:22 GMT 2015 armv6l GNU/Linux.ā€
What was the event that you scheduled? We’re trying to find root cause here, it’s been tough to locate.
I’m going to re-open this bug too.
I didn’t have an opportunity to schedule an event or do anything else. I installed Cayenne on my RPi, and the emails immediately started coming in (I received the ā€œmyDevices Cayenne - Install Completeā€ email at 9:02pm and received my first cron email at 9:02pm as well, then every minute thereafter until I could change my crontab). I don’t know if it matters, but I have installed a few other packages on RPi (before installing Cayenne) that I use for other projects, including Apache, ssmtp, ouimeaux and node.js.
