Hello All,
I’m trying to install Cayenne from a terminal window with the wget command using “my url” but I get 404 not found.
Can someone please point me in the right direction to install from a terminal window.
that usually means a mistype on the install text… Can you try again?
The letter L and the number 1 can sometimes be confused.
Thanks,
Yes is was the letter L. I ended up copying the text into Word and changed the font so I could figure out it was a “L” not a “1”.
issues. Thanks for the quick response.
Phwew, glad to hear it. See you around!
